has anyone used a st215 trans in a st185?
lalojamesliz1
New member
I looked but the st205 swaps are not as plentiful as before but the st215 trans are. would it be a simple swap or does anything else need to be done to make them work in a st185?
I have a gen3 st205 engine in my car if that matters
Tecker185
Member
Your speedo will not work, the drive inside the trans is missing. Other than that its bolt in.
Magroo
New member
From what I understand about the st215/246 transmission, there are no gear teeth in the place you can plug in the speedo cable/electronic speedo. It gets the speed signal from the wheel sensors and the ecu sends the signal to the instrument cluster
Top
