My new All-Trac St185
• Page 2 of 3 • 1, 2, 3
Re: My new All-Trac St185
Yes. That was the first thing I checked. Do you think the dimmer knob can go bad?
1991 Toyota Celica All-Trac White (239,000 miles)
1991 Toyota Celica All-Trac Black (163,000 miles)
- alltrac801
I don't see why it couldn't, I had one die in one of my old Jeeps. I can't remember if it dims the HVAC bulbs too though.
I guess I can check my other car when I get home but I thought it did dim the HVAC. I might have a spare headlight switch anyway that I can throw at it.
- alltrac801
Got the windows tinted and man does it look so much better!
- alltrac801
No more purple windows. Sweet!
simple - Club Member
- Images: 1
Its such a small change but it makes a huge difference! I'll take better pictures when the weather isnt bad and i can get her cleaned up again.
- alltrac801
Got the front bumper off and getting it painted today! Should have it back in a couple of days!
- alltrac801
Finally got my bumper back from paint and installed and man does it look good!
- alltrac801
Now I'm thinking about adding some sort of heat dissipation for under my ARC intercooler. What do you guys recommend?
- alltrac801
Just got my All-trac back from getting the clearcoat re-finished using restoreFX and damn it came out good! Pictures don't do it justice and my dumb ass didn't take a before picture!
- alltrac801
Wow that looks fantastic
Regarding the ARC intercooler heat dissipation, I think it's worth while to look into creating a new scoop shroud to allow more airflow through the intercooler. The stock rubber shroud blocks a bit of the cooler. On mine I created an aluminum duct which I've found does a good enough job.
Corey - GTFour God
- Images: 50
Thank you! I was really blown away by the detail job! Do you have any pictures of what you did? I really like the ARC and want to keep it I just want to make sure I'm getting the best performance out of it as possible.
- alltrac801
Used cardboard and tape to make a rough version and to get the clearances right, then cut out the pieces from aluminum and took them to a shop to get welded. It's secured to the hood with the original screw holes.
I've considered adding thin strips of foam rubber around the edges to improve the seal, but I have the clearances pretty close and it does a good job as is. There is about a 3-5mm gap all the way around which allows for engine movement. I had to file down the back edge in particular after driving around because the original clearance was so close that the intercooler was rubbing against the duct when the engine moved.
Corey - GTFour God
- Images: 50
That looks really nice I'll definitely look into that! Thank you. Do you have any rattle with it at all?
- alltrac801
Thanks. I originally tried just stacks of adhesive foam rubber weather stripping stuck to the hood around the scoop. And while that worked, it looked terrible and didn't last long.
I don't think I've noticed any rattling from it. I've had it on the car for about 8 years now.
Corey - GTFour God
- Images: 50
