Billet blocks
autojumbled
New member
I'm never going to need a billet engine block but it's quite exciting to see what it will be capable of. Given it's coming from DP Engines though....I'm assuming it'll find its way into a very fast MR2 at some point!
transneptunian
New member
Yea. Honestly will prob never be running the power that would justify it but I can’t wait to see what people are going to do with them.
Moderator
I’d be interested, depending on price, and if you are allowed to make any changes. I wouldn’t mind a bit higher deck height.
Well-known member
I'm curious what people are planning to use these for seeing as the 5S block is already good for pretty crazy levels.
transneptunian
New member
Yea but even the 5s tops out at around 1000hp. With billets we could see 1500+ putting us on par with other top power 4 Cyls.
transneptunian
New member
RedCelicaTRD":1lcxffm7 said:
Have you heard if it’s going to be a wet block or dry?
I’ve heard they have the option to do either. I guess you’d have to talk to the maker about what specs you want.
Top
