driveshaft joint
88st165
New member
there is a joint about at the middle of the car that looks like it is held together with 6 allen head bolts similar to the cv axels..... does that joint need servicing? the reason i ask is because there is grease splatter on the underbody that is directly where that joint is located.
Top
