Nitro_Alltrac
New member
That's what I thought.
Thanks Tim!
Thanks Tim!
smog7":a2dlrav3 said:damn this is coming out to be expensive. I think I should have just taken it to a shop. I would have paid a little more, but I wouldnt have had to deal with all the bs. so the bearings and seals each need to be ordered separately...
so im guessing I need the front hub seals and wheel bearings under "front suspension components" are the ones I need? And for the rear I couldnt find any hub seals, instead I found wheel seals. Is this what I need?
new order list:
-front wheel bearings
-front hub seal
-rear wheel bearings
-both inner & outer wheel seal
Is their anything else that I will need?
