theft and recovery
"Today I started my car, it was in Reverse when I started it and the entire car shook!"
Did you have your foot on the clutch when you turned the key?
Sounds like your hydrolic system is having trouble pressurizing. do gears engage easier after pumping the clutch? spend an afternoon looking over all the hoses for leaks or cracks.
Does anybody know of an easy swap to improve the pressure? another Toyota item found at a wreckers maybe?
