yellowtuner
New member
just wanted to know whats the easiest way to get to the lever on the tranny to switch it to 2wd
well when it ulocks the diff. isnt that the same as disengaging the rear so only the front tires spin?4V6":3s0wnk2a said:I presume this is the lever and quadrant on the alltrac transfer case?
It dosent switch from 2 to 4 or 4 to 2 wheel drive with that, it simply locks the diffs together or unlocks them. Might be fun on the snow or mud but the tranny wont like it on pavement.
im not sure cuz out here in cali the smog rules are more strict! i dont think i have ever seen a awd smog station. how many people have done it at idle or rollers?rezeeb":q63myaoq said:When I had mine checked, they just did an idle and ~2500 rpm text. They did not run it on rollers. The smog station should be set up for running an awd car or just do rpm tests off rollers.
yellowtuner":3t0m6d15 said:well when it ulocks the diff. isnt that the same as disengaging the rear so only the front tires spin?4V6":3t0m6d15 said:I presume this is the lever and quadrant on the alltrac transfer case?
