ST165 v ST185 Engine mounts
Postby freddie » Mon Jul 16, 2018 2:24 pm
Are there any differences between engine mounts for a ST165 Celica and a ST185? I believe the front and rear mounts are the same,
but I am told the top left and right are different? I have seen the timing belt end mount with a balance weight thing on top of it. The engine mount on top of the transmission looks the same on both models?
Can any one help here?
I know the engine mounts on the ST205 are very different.
Thanks in advance.
freddie
Re: ST165 v ST185 Engine mounts
Postby freddie » Wed Jul 18, 2018 2:03 pm
Hey guys,
Please can somebody tell me? You see I can get these engine mounts and the seller tells me the ST165 mounts are the same as ST185
Cheers
Freddie
freddie
Postby r-town » Wed Jul 18, 2018 7:02 pm
They have different part numbers:
ST185:
12362-74140 (RH)
12372-74230 (LH)
ST165:
12362-74040 (RH)
12372-74070 (LH)
Comparing the mounts:
The ST185 LH mount has an additional mounting hole:
https://www.dropbox.com/s/j7m0uo6p2v5m1 ... 1.jpg?dl=0
The ST185 RH mount has a top stud.
http://i60.photobucket.com/albums/h32/D ... ts_030.jpg
Some members say that 3 out the 4 mounts fit into the ST165, however I only own a ST185 so can't confirm this 100%.
r-town
