Need Shift Cables
Re: Need Shift Cables
Postby alltrac801 » Sat Sep 28, 2019 1:17 pm
That's way nice if they fit the St165 too. I'm just glad there is a relatively cheap option for new shift cables for our cars! Of course that's after I paid way to much for a used pair.
alltrac801
Postby JRWperformance » Wed Jan 01, 2020 5:07 am
Looks like they are different from the ST165. I took forever getting back to the project. The dimensions are a bit off. The left/right cable is about 2 inches too long. Looks like I'll be cutting the cables up. The cable housing will be fine though. I'll be replacing the trans side with a threaded rod end for some adjustment.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby JRWperformance » Sun Jan 26, 2020 12:09 am
I did the measurements and modified my MR2Heaven ST185 cables to fit in my ST165.
I cut 16mm of length off the CABLE for the forward and back shift cable. And I removed 48mm from the side to side cable. There was enough material to cut it off the shifter side and weld back together. I have them in the car and they feel great! I also installed my spherical bearings into the trans side to get rid of the crappy rubber bushings. I did nothing to the cable housings themselves.
Hope this helps the ST165 guys that need cables.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby alltrac801 » Mon Jan 27, 2020 7:09 pm
Nice! This will probable help a few people!
alltrac801
