ST185 Shifter Cables
Postby calyzoo » Fri Aug 05, 2022 2:05 am
I picked up a set of shifter cables from MR2Heaven a while ago and just got around to swapping them in. Pulled my existing cables and noticed the lengths are a bit different. The new cable and housing are ~3/4" longer.
I searched the forum and found some of you shortened the MR2Heaven cables to fit your ST165 but they seemed to be off by 2".
Wondering if anyone has installed these cables directly in their ST185 without any issues. Not sure if 3/4" would cause any issues or not.
90 ST185
03 Tundra T3
20 RAV4 Hybrid
calyzoo
Re: ST185 Shifter Cables
Postby abeans » Fri Aug 05, 2022 9:38 pm
Alltrac 101 had a youtube about this. They don't fit right on 185.
That said, i do have a used set of cables, that did work when removed.
1990 St185 Celica
@abeans07 i post car stuff
abeans
Postby Mandrew » Wed Aug 10, 2022 7:46 am
Assuming calyzoo doesn't take you up on it, I would be interested in the shift cables. P.M. sent also...
abeans wrote:Alltrac 101 had a youtube about this. They don't fit right on 185.
Mandrew
Postby calyzoo » Wed Aug 10, 2022 1:10 pm
I appreciate the offer, Mandrew! I've decided I'm going to cut mine down and weld them back to match the length of the old ones.
90 ST185
03 Tundra T3
20 RAV4 Hybrid
calyzoo
Return to Drivetrain Central
