Bringing a ST185 back from the dead one last time
Re: Bringing a ST185 back from the dead one last time
Postby awdmofo » Mon Mar 26, 2018 4:44 am
crackerjack wrote:
I found mine in June and very close to your story and it is a 91 altrac in white.
Guy did say blown head gasket but sat there for 2 years so the entire engine needed
to be rebuilt.
Now, it is running!!!
Did all the work myself, still have a few things left to do, Its christmas, taking a break and
enjoying the ride.
Sweet ride!! Where you located? I could use some experienced advice because Im about to pay a local shop in ontario to finish the engine rebuild. I'm low on time but finally got a raise at work so you know what that means... MORE CAR PARTS :rofl:!!! I'm suppose to bring the block, head and pistons to my guys shop this saturday 3/31/18. I need to clean the engine bay, remove the rack to get rebuilt, buy all new vacuum lines and what not and get the starter/alt rebuilt. So much fun stuff :roll: .
1990 All-trac current money pit (being rebuilt) :roll:
2nd gen Part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53417&p=489623#p489623
Full interior part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53399
awdmofo
Postby crackerjack » Mon Mar 26, 2018 12:43 pm
Located in Calgary, Alberta.
Since there aren't that many alltrac in Canada, less than 1000(LHD). I suggest going to Rockauto for parts.
I go to Discount toyota parts that is located in Toronto for OEM parts like turbo drain hose, valve shims, timing belt...etc.
Thinks like water pump i would go to Rockauto as they have really good pricing to Canada. Believe it or not, OEM piston are no longer available through Toyota so I go Ebay for replacement 3SGTE piston 86.5mm
If yours is a 91, then highly recormend you buy complete engine overhaul gasket. There is someone in the UK that
makes a complete kit that includes timing cover gasket(this is the hardest to find). They are all on ebay. Also,
you should buy the cometic Metal head gasket as they don't stock it(made to order). There is a set of OEM TTY bolts in Toronto but its $289.00. Mine are ARP Head studs at $180.00
also, pay attention to your power steering pump, if that leaks, its a pain to get it out(thats my issue right now).
Alternator and starter are on top so its easy to get to.
Good luck..... :D
crackerjack
Postby awdmofo » Thu Aug 29, 2019 5:58 pm
crackerjack, sick ride and good to hear another rebuild story! A lots happened in the last 3 years, finished my B.S. degree, my father passed away 2.5 years ago so that put a damper on my project cars :( . But after all that I'm finally putting the pieces back together!!! New pics to come and updates so stay tuned!!! :D
I hand cleaned the pistons, removed the old rings and sent it to the shop with my fresh rebuild stock 2nd gen head. Crossing my fingers they put it all together asap. I'm hoping to have it running and driving safely this winter.
awdmofo
Postby awdmofo » Sun Sep 08, 2019 5:30 pm
Cleaned up the CT20b, painted my stock exhaust manifold black with high temp paint and will be arranging parts in anticipation for my engine/trans to come back from the shop with a new clutch/flywheel installed as one large piece I can throw into the engine bay. Currently looking to rebuild or buy an aftermarket steering rack, rebuild the alternator, starter and powersteering pump. Also need to clean up the engine bay, paint some of the areas that are scratched with touch up paint and source some new engine/trans mounts. Any suggestion on where to get white spray paint that matches the stock color? Any suggestions on the engine mounts? :notworthy:
awdmofo
Postby sefiroxx » Wed Sep 11, 2019 4:19 am
I have had local automotive paint suppliers make up rattle cans for me for quick touch up to hold things until a full paint job. Check with them
sefiroxx
Postby awdmofo » Wed Sep 11, 2019 4:43 pm
sefiroxx wrote:I have had local automotive paint suppliers make up rattle cans for me for quick touch up to hold things until a full paint job. Check with them
Paint shops can do that? Do you know of any near the LA or OC area here in California? Any pointers on where to sorce the specific color/color code? Thanks.
awdmofo
Postby alltrac801 » Thu Sep 12, 2019 3:06 pm
I know there is a company that sells through amazon that does aerosol paint cans for factory colors. I haven't used them before but maybe someone on here has. I bought a little touch up pin on amazon and it was a great match.
1991 Toyota Celica All-Trac (239,000 miles)
alltrac801
Postby sefiroxx » Thu Sep 12, 2019 7:23 pm
Used English color locally in TX. You can go online from. . .
https://www.automotivetouchup.com/spray ... tched.aspx
. . .Which will run you through make/model selection getting you to color with the mfg number
sefiroxx
Postby awdmofo » Thu Sep 26, 2019 5:05 pm
alltrac801 wrote:I know there is a company that sells through amazon that does aerosol paint cans for factory colors. I haven't used them before but maybe someone on here has. I bought a little touch up pin on amazon and it was a great match.
Thanks! I'll look into it. I was at autozone the other day buying more engine degreaser and brake clean and they said they sell cans of touch up for my color "toyota super white" (Dupli- color PN#BTY1556) for $10.49 but they were out and the only store near had 1 can that was like 8oz i believe. I'll need 2 at least to do the engine bay.
awdmofo
Postby awdmofo » Thu Sep 26, 2019 5:07 pm
sefiroxx wrote:Used English color locally in TX. You can go online from. . .
Great find! thank you. if i can't find these small autozone cans locally this week i'm ordering 2 of these. You've used them before? I'll let everything know what i get regardless and how well it matches. :D
awdmofo
Postby awdmofo » Wed Oct 02, 2019 8:39 pm
Finally removed the A/C condenser and lines and also crawled up under to manually lower the headlight. I think I know why the motor went back on the headlight... Notice the picture of the alignment of the fender to the headlight :? . Also barely tugged on the side marker light and it broke in my hands like 30 year old plastic :doh: . I guess its time for clear JDM lights?? ANywhoo more pictures!!!
awdmofo
Postby awdmofo » Sat Oct 12, 2019 9:27 pm
Thanks to http://www.imgur.com I now have updated all the original links for my pics on Page 1-3 so I hope it helps if anyone is following me from the beginning :D . So I got my power steering pump rebuilt and got a new sensor on it, got the starter rebuilt and picked up a nice replica GT4 front bumper from some cool local company (http://www.vicrez.com). Now if I can only talk them into making GT4 hoods because i can't find one anywhere and I wanna install this 205 water to air intercooler asap.
**shameless plug of my 3sgte part out and full interior post** Help me afford to get this guy up and running!
awdmofo
Postby underscore » Sun Oct 13, 2019 2:40 am
I've been tempted to get one of those front bumpers just to have a spare on hand. Let us know how the fitment is.
Postby awdmofo » Mon Oct 14, 2019 1:45 am
underscore wrote:I've been tempted to get one of those front bumpers just to have a spare on hand. Let us know how the fitment is.
I'll be fitting it this week and let you know. The shop i got it from told me they sell a ton of these. If thats true i'd assume they fit great. They told me to let tem know if I have any problems or issues at all. I hope i can get a list of people willing to buy the GT4 hood soon, they should be able to make it out of fiberglass or carbon fiber. I will allow them to use my stock hood for measurement... for a discounted price :P .
awdmofo
Postby awdmofo » Wed Oct 23, 2019 8:56 pm
Got a rebuilt OEM steering rack for $150!! :D My BRD steering rack bushings came in along with the BRD shifter bushings. Ordered some Kirkosaurus front and rear engine mount inserts, they will hopefully make this a solid feel once i get it running.
My stock blown steering rack bushing and tie rod ends...
LOOK MOM NEW PARTS!! :shoots:
awdmofo
