Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby Rick89GTS » Sat Aug 11, 2018 3:08 pm
Did you weld on a longer steel exhaust hanger or did you get a different rubber hanger?
zaluss wrote:November 22nd 2015
One of the exhaust hangers doesn't reach. I'll need to get a longer one.
Rick89GTS
Postby zaluss » Sun Aug 12, 2018 3:14 am
Rick89GTS wrote:Did you weld on a longer steel exhaust hanger or did you get a different rubber hanger?
I got a different rubber hanger. Some generic longer one.
zaluss
Postby Rick89GTS » Sun Aug 12, 2018 9:23 am
OK, that's great; don;t have to muss that chrome finish!
Rick89GTS
Postby mickeyfinn » Thu Jan 10, 2019 9:21 pm
Thank you so much for posting all this information! It has been tremendously helpful! I love your car! I've come across it in a few places. I may follow in your footsteps.
I have an ST165 that is in fantastic shape, but the engine needs to be rebuilt (has 88,000 original miles). I'm debating whether to get the engine current engine rebuilt, and keep it all original; or swap it out with an ST205 engine like you did. What would you reccomend? Seeing that you've done the swap, is it better/worth it? Do you still have your car?
Thanks!
mickeyfinn
Postby zaluss » Fri Jan 11, 2019 5:02 pm
mickeyfinn wrote:Thank you so much for posting all this information! It has been tremendously helpful! I love your car! I've come across it in a few places. I may follow in your footsteps.
Thanks!
Thanks for the kind words!
I still have the car though I post most of my updates on Instagram (@project165) or on the alltrac fb page.
Swap is absolutely worth it for reliability and part availability alone. Unless you are planning on keeping it as a collectors car, I would swap ahead. Feel free to message if you have questions.
zaluss
Postby mickeyfinn » Sat Jan 12, 2019 7:37 pm
Thanks for the reply.
Is there a huge performance difference comparing the original ST165 engine to the swapped ST205? I would like to keep the car as original as possible, BUT, the ST205 has about 50 or so more hp. That's hard to ignore. I'm just nervouse about everything working after the swap. I may even have ATS racing do the swap. Apparently they have done it many times, and even have one in the shop now that they just finished swapping.
Here are some pictures of mine by the way.
mickeyfinn
Postby underscore » Sat Jan 12, 2019 8:04 pm
With how clean and original that looks, I'd at least hold onto all the stock parts if you can.
Postby zaluss » Thu Jan 17, 2019 12:42 am
mickeyfinn wrote:Thanks for the reply.
Yes its worth it for reliability and part availablility. Probably more than 50 hp because you can crank the boost higher than on the 1st gen engine.
zaluss
Postby SkagTits165 » Sat Jan 19, 2019 4:42 pm
Dont waste a single dime on the stock genI engine. ST205 powerplant is what you want and need
viewtopic.php?f=6&t=51709
SkagTits165
Postby GT4times2 » Tue Jan 22, 2019 2:06 am
SkagTits165 wrote:Dont waste a single dime on the stock genI engine. ST205 powerplant is what you want and need
If it's done for, I agree. Go Gen 3 or later. Well worth it.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 (MRP) Gen4
90 ST185 (Gray) Not sure what gen yet.
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby mickeyfinn » Wed Sep 11, 2019 2:52 pm
Zaluss,
Do you remember the part number, and where you got the heat exchanger for upgrading your IC in this post?
I'd like to do the same.
Thanks!
(would also like a T-shirt like your girlfriend was wearing in one of those posts, where could d i get one?)
zaluss wrote:End of Summer Upgrade
I spent the last few weeks upgrading a few key components:
1) Larger heat exchanger.
2) Larger IC pump
3) Heat wrap top mount heat exchanger
4) Cut and fiberglass the ST205 original airbox.
5) Run a force-fed intake from the lower front bumper. Inspiration from here: http://www.alltrac.net/phpBB2/viewtopic ... 44&t=50901
6) Battery relocation to trunk.
Heat exchanger arrives.
Xbox One S controller for scale.
Draining the coolant from the original IC.
Intercooler removal.
Bosch/cobra pump installed.
Using zip ties to measure positioning.
Using some threaded rod and rod ends, heat exchanger mounted.
Heat wrapped the top mount intercooler
Fiberglassed and fitted ST205 airbox. No pics of fiberglass process (sorry). It required the entire bottom section to be cut and fiberglassed over.
Used an aluminum project box to store my various fan and accessory relays.
Cut a 3" hole to run the air ducting to the factory airbox.
Bumper hole still needs some triming.
Battery mounted in the rear passenger hatch.
Still a few more things to do so I'll add more pictures once completed.
mickeyfinn
Postby zaluss » Wed Sep 11, 2019 7:17 pm
mickeyfinn wrote:Zaluss,
Thanks!
This is the one http://www.frozenboost.com/water-to-air ... 178dce23a9
It was a long time ago. I couldn't find the site :(
zaluss
Postby Rick89GTS » Sat Jan 25, 2020 5:55 pm
Zaluss, sent you a PM :)
Rick89GTS
