Project CMS
Re: Project CMS
Postby abraxxa » Sat Nov 28, 2020 1:35 pm
Great to see how people look which you know for years from forums :)
One thing I notice is different sound volumes from video to video, escpecially the one about the hub extension is quite muted.
Maybe you can use a microphone attached to your shirt, would improve the quality a lot.
Besides that keep up the great work! :notworthy:
facelift ST205
abraxxa
Re: Project CMS
Postby CMS-GT4 » Sat Nov 28, 2020 2:27 pm
Thanks. I’ve got to work on my audio for sure. I used to have a lapel mic but the wire got ruined when I was doing exhaust sounds on time. I ordered a wireless mic Thursday so hopefully I have can note uniform clear audio in the future.
www.noritoy.com | www.coldironworks.com | http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=19891
Re: Project CMS
Postby abraxxa » Sat Nov 28, 2020 2:40 pm
:D
facelift ST205
abraxxa
Re: Project CMS
Postby CMS-GT4 » Wed Dec 16, 2020 3:23 pm
A new video is up on repairing the center column plastic with a 3d printer.
https://youtu.be/0SOtiLCOnFk
Re: Project CMS
Postby GT4times2 » Wed Dec 16, 2020 4:47 pm
Well done!!! Are you going to provide this service for others? Just asking, lol. :shrug:
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 (MRP) Gen4 swap
90 ST185 (Gray)
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
88 St165 (white)- 2020 Project
GT4times2
Re: Project CMS
Postby CMS-GT4 » Wed Dec 16, 2020 5:16 pm
GT4times2 wrote:Well done!!! Are you going to provide this service for others? Just asking, lol. :shrug:
I might come up with something to offer. I had to grind on a a couple of them and they may not be a one size fits all situation. So if I sell something it would be left up to the person to tweak them to resolve their problems.
Re: Project CMS
Postby GT4times2 » Wed Dec 16, 2020 5:25 pm
Makes sense. Keep us posted.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 (Gray)
GT4times2
Re: Project CMS
Postby FC Zach » Thu Dec 17, 2020 10:12 am
My screw holes are busted too, I'd be interested in a kit if you made a few extra.
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: Project CMS
Postby CMS-GT4 » Wed Jan 06, 2021 5:36 am
New year and a new video.
I’ll try and do some math and see what I can come up for the caps and what I’d charge etc.
https://youtu.be/MGeMcB0qIcI
Re: Project CMS
Postby Corey » Sun Jan 10, 2021 11:46 pm
That's the first I've heard of using a Prius knuckle on the Celica - really interesting idea.
Corey
Images: 50
Re: Project CMS
Postby CMS-GT4 » Mon Jan 11, 2021 5:36 am
Corey wrote:That's the first I've heard of using a Prius knuckle on the Celica - really interesting idea.
It’s been around for a while. A member who owned a ct200h first came up with it. Only a few have successful done it. The scca st165 road course car likely has the most dialed in setup of this. It is not a bolt on affair though. The axle spline is really the true compatible component. The rest needs to be adapted.
Re: Project CMS
Postby Corey » Mon Jan 11, 2021 8:10 pm
I'll do some reading up on it. It looks like the bearing isn't pressed in right? Just bolts on?
Depending on how much adapting is needed, that alone would be a great feature.
Corey
Images: 50
Re: Project CMS
Postby CMS-GT4 » Mon Jan 11, 2021 8:29 pm
You need a new lower mount for a coilovers meant for a Prius. That is one of the big ones. You also need to taper for the ball joint and possibly tie rod end. The biggest challenge is geometry settings. These are not universal as there are factors involved that sort of makes most builds unique. So you would need a custoM adjustable ball joint as well tie rod end to dial in these adjustment. You would also need to come up with new front brakes or use Prius brakes.
The bearing does bolt on making that a big advantage.
Re: Project CMS
Postby CMS-GT4 » Fri Jan 15, 2021 4:05 pm
New vid up. Going to try and do 2 a month this winter.
https://youtu.be/k31mD0cWuk0
