Project CMS
Postby illGT4 » Sun Jun 17, 2007 6:43 pm
etantshi wrote:Time will tell if the LSD vs non LSD will be as dramatic a difference as you have experienced. I hope it is. Thanks for the LSD josh, good luck on your vac problems.
If it helps any-
I can drastically tell the difference between my RC (LSD) and '90's (non-LSD) All-Trac's that I own.
It's the reason I bought a 205 rear sub. w/ LSD for my (white) '90 All-Trac. Some time down the road, I'll buy another rear diff w/ LSD for the (black) '90.
If you are sporting the car - spirited driving - or track use. LSD is a huge advantage.
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby CMS-GT4 » Sun Jun 17, 2007 7:16 pm
BTW: I just dug out my old window sticker. My car sold for 27,018.00 back in 1992. Almost as much as I paid for my Z just a couple of years ago. Base price was 22,048.
I think if they could have dumped some of the options and got the price 20k the DSM might not be as popular.
Postby etantshi » Sun Jun 17, 2007 9:40 pm
If it helps any-
I think it will. I've always felt that it was missing something, even when I put on the whiteline works package.
CMS-GT4 wrote:BTW: I just dug out my old window sticker. My car sold for 27,018.00 back in 1992. Almost as much as I paid for my Z just a couple of years ago. Base price was 22,048.
I agree. The AT had many options that were only available on many of the luxury lines. Power lumbar seats, auto climate control, leather, sys 10, theft system. And also considering that 27k 15 years ago was probably closer to 35k by todays standards.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby etantshi » Sun Jun 17, 2007 9:43 pm
Actually:
What cost $27000 in 1992 would cost $38551.48 in 2006.
Also, if you were to buy exactly the same products in 2006 and 1992,
they would cost you $27000 and $18909.78 respectively.
http://www.westegg.com/inflation/
André B.
etantshi
Postby CMS-GT4 » Mon Jun 18, 2007 1:42 am
Took the car for a little test drive. Still pulling timing up top. Runs decent though. Matter of time before I kill the last of the gremlins.
http://s127.photobucket.com/albums/p136 ... I_4970.flv
http://s127.photobucket.com/albums/p136 ... I_4971.flv
http://s127.photobucket.com/albums/p136 ... I_4972.flv
Took a few pics too.
Postby alltracshoak » Mon Jun 18, 2007 6:47 am
looking good with those beefy tires ..wish i can score a set of those..i vote more vids when you finally get it running at full potential
Current 1992 teal st185- 2018 - in pieces trying to pit back together
90 black st185 - 2018 - sold 2018
90 black st185 -sold 2010?
rip: 92 white st185 @ 178k :(
alltracshoak
Postby Kyoto » Tue Jun 19, 2007 4:36 am
Josh FWIW vaccum at idle should be between 20-22 psi.
17 psi sounds like there is still a minor leak somewhere.
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
Postby alltracshoak » Tue Jun 19, 2007 5:13 am
also, w/o that rear spoiler, it looks so aggressive.
alltracshoak
Postby CMS-GT4 » Sat Jun 23, 2007 2:15 am
Had to drive the car ~40 miles to work today. Felt interesting on the highway.
I know my gearing is conciderably higher, but what do you guys rev for crusing at 70mph?
Mine sits at 2,800 rpm.
Postby CMS-GT4 » Sun Jun 24, 2007 5:42 pm
Just got a set of Evo 8 brembo calipers.
I am going to use the fronts and most likely the st205 rears.
I might put the rear brembos up for sale, unless I try and fit them on the rear as well, thenthe 205 rears will go for sale.
I will most likely use the 205 ones so I do not have to make brackets. If I do use the evo rears I will still use the rear discs from the st205.
I will most likely use sti rotors and a spacer.
Plus my oem setup will most likely go for sale to help cover the cost.
Postby CMS-GT4 » Mon Jun 25, 2007 10:24 pm
Got my new catch can in today. It helped out a lot. Vac is now 19 at idle. Idle is better and does not dip as much. So there is still a small vac leak at large.
THe car sounds louder and more aggressive now too. It also pulls harder. Can't wait to sort out all these vac issues. I think I am almost there.
Postby smog7 » Tue Jun 26, 2007 12:04 am
my car is at about 3k at 70mph.
-omar
rally tarmac 1990 st185
smog7
Postby CMS-GT4 » Tue Jun 26, 2007 12:13 am
Interesting. So, my ratios knock it down only a couple hundred rpm.
Postby alltracshoak » Tue Jun 26, 2007 3:44 am
i thought vacumn at idle should be anywhere from 18-22 psi?
alltracshoak
Postby CMS-GT4 » Tue Jun 26, 2007 12:52 pm
All the 3rd gen guys tell me mine should be at 21.
