I'm back.... I have been away due to having to rebuild the engine again...
Due to a bottom end failure, not exactly sure what caused the failure but we think it was the journal bearings or thrust bearings and after the bottom end was rebuilt there was a knocking noise coming from the head. So removed the head had it all checked out and about the only thing they could find was that the cams looked a little bad, maybe.
So replaced the cams and etc... after head was rebuilt and everything was put back together it seems to be running fine. So breaking in the engine again and driving it with just stockish boost which is better then nothing for now... After break in I will need to have it retuned and dynoed for new numbers.
