alltracshoak's 4th st185... 92 teal
alltracshoak
Active member
car died because of a short somewhere.took whole wiring harness off but where to go after this???
i recently bought a multimeter from sears for $40 but dont quite know how to use it and wht to diagnos when my harness is off
electric gurus please help!!!i need to get back on theroad asap so i can rock my GT4 AWD plates
phattyduck
New member
Start with a visual inspection! Are there any chaffed/crushed areas?
Shorts are hard to diagnose, but easy to visually spot (generally). Broken connections are easier to find with a multimeter. Intermittant connections are the worst. :(
Good luck.
alltracshoak
Active member
ok today i took off my wiring harness.i've checked all my plugs which the black wire with yellow stripe goes to(tvis vsv,turbo pressure sensor,turbo vsv,egr,o2 sensor,check connector) and they all was ok with no short.i also check to see if any of those wires are touching the engine ground and none of them was.anyone can pin point me how many ohms does all those sensor ive mention above have to be in specs ??im only usuing my phone for access so it really sucks
alltracshoak
Active member
no short???im lost now with the electrical. anyone has a good usdm 90 alltrac wiring harness?????i may want to buy or trade with something...
alltracshoak
Active member
up and running now..rewire some broken/short wires and it runs again!!!somehow develope boost leak so will have to look into that
alltracshoak
Active member
got the ct20b in and man it was a nice upgrade from the ct26.i should of never sold the one i had before.pulls hard till redline.not even my youbger bro mr2 turbo could keep up to me now
alltracshoak
Active member
too much boost is the problem now.im hitting 1.40-1.50 bar then backed off.scary.i dont know if a boost controller will help control this boost problem.everything is hooked up right and even the factory tvsv is still hook up too
any help?
that will be from 20-22 psi.
alltracshoak
Active member
bored random pics for my portfolio
Top
