alltracshoak's 4th st185... 92 teal
Postby alltracshoak » Wed Dec 16, 2009 6:19 am
car died because of a short somewhere.took whole wiring harness off but where to go after this???
i recently bought a multimeter from sears for $40 but dont quite know how to use it and wht to diagnos when my harness is off
electric gurus please help!!!i need to get back on theroad asap so i can rock my GT4 AWD plates
Current 1992 teal st185- 2018 - in pieces trying to pit back together
90 black st185 - 2018 - sold 2018
90 black st185 -sold 2010?
rip: 92 white st185 @ 178k :(
alltracshoak
Postby phattyduck » Wed Dec 16, 2009 7:40 pm
Start with a visual inspection! Are there any chaffed/crushed areas?
Shorts are hard to diagnose, but easy to visually spot (generally). Broken connections are easier to find with a multimeter. Intermittant connections are the worst. :(
Good luck.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby alltracshoak » Thu Dec 17, 2009 3:30 am
ok today i took off my wiring harness.i've checked all my plugs which the black wire with yellow stripe goes to(tvis vsv,turbo pressure sensor,turbo vsv,egr,o2 sensor,check connector) and they all was ok with no short.i also check to see if any of those wires are touching the engine ground and none of them was.anyone can pin point me how many ohms does all those sensor ive mention above have to be in specs ??im only usuing my phone for access so it really sucks
alltracshoak
Re: alltracshoak's st185
Postby alltracshoak » Sun Dec 27, 2009 8:23 pm
no short???im lost now with the electrical. anyone has a good usdm 90 alltrac wiring harness?????i may want to buy or trade with something...
alltracshoak
Postby alltracshoak » Sun Jan 03, 2010 7:08 pm
up and running now..rewire some broken/short wires and it runs again!!!somehow develope boost leak so will have to look into that
alltracshoak
Re: alltracshoak's st185(ct20b+water inj)
Postby alltracshoak » Sat Feb 06, 2010 5:14 am
picked up a ct20. and maybe install tomorrow.we'll se how this minor upgrade is with my water injection
alltracshoak
Re: alltracshoak's st185 (ct20b+water inj)
Postby alltracshoak » Sat Feb 06, 2010 7:09 pm
got the ct20b in and man it was a nice upgrade from the ct26.i should of never sold the one i had before.pulls hard till redline.not even my youbger bro mr2 turbo could keep up to me now
alltracshoak
Postby 88st165 » Sat Feb 06, 2010 10:48 pm
Yeah I also noticed a difference when I swapped to a ct27. Its def a nice upgrade.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby alltracshoak » Sat Feb 06, 2010 11:40 pm
too much boost is the problem now.im hitting 1.40-1.50 bar then backed off.scary.i dont know if a boost controller will help control this boost problem.everything is hooked up right and even the factory tvsv is still hook up too
any help?
that will be from 20-22 psi.
alltracshoak
Postby smog7 » Sun Feb 07, 2010 9:27 pm
^damn! do you have a fuel cut hooked up?
-omar
rally tarmac 1990 st185
smog7
Postby alltracshoak » Tue Feb 23, 2010 1:01 am
bored random pics for my portfolio
alltracshoak
Postby CMS-GT4 » Tue Feb 23, 2010 1:47 am
Car looks good.
92 st185 (205 swap) | 03 350Z Track (sold) | 13 Pilot | 17 Mazda3 | 12 Vroom Vroom
linktr.ee/ColdironWorks | www.coldironworks.com | http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=19891
Postby alltracshoak » Tue Feb 23, 2010 3:49 am
car doesnt look that good in person..the hood and bumper needs some touch up
alltracshoak
Postby alltracst185 » Tue Feb 23, 2010 1:24 pm
Looking good :smokes:
alltracst185
Postby alltracshoak » Tue Feb 14, 2012 9:59 pm
quick update
alltracshoak
