If you asked me earlier today I would have said this turbo sucks. I was getting full boost at 4500 or later but I just went on an open road trash and I think it is starting to "wear in" or something. I can get full boost by 4000 and it seems to be getting much more responsive lower in the revs. I can pull up to 4psi in low gears.
Whats really awsome is that I thought I was going to have to start changing down on hills etc due to being way outside the new torque band but I can pull 4-5psi in 5th at 2000rpm and still accelerate slowly up a hill (not that I plan to do that ever again)
I am not sure about the MPG thing. I definitely see where you are coming from, I thought the exact same thing until the last drive I did where I am sure even though the boost is lower, I am still flowing at least as much as the ct26 at the same revs in the same gear. It has impressive pull down low.
Anyway so yeah this thing is great! It gets better with every drive. My kit seems to be holding up perfectly fine. I made an exhaust support from 4mm alluminium today for the bottom of the downpipe similar to the ats and ko kits to stop the stainless DP cracking.
Also I get a really foul smell every time I boost hard, possibly crap still steaming off the new turbo + I spilt oil all down the head and below the filter when doing my oil change.
I find it hard to feel how much faster the new turbo is but my gf assures me that it is way faster than the old one and she actually screamed at the top of 2nd and 3rd which has never happened before
