Project Stormbringer - Antidisassemblementarianism! (03/22)
Postby Dracov » Wed Jul 23, 2008 7:34 pm
...well, a year plus a day to be technical. But that's how long it's been since I brought home my favourite car in the world and achieved an old dream of mine; A 1988 ST165.
Canadian market, so everything was metric. 107,000 miles and a healthy stack of service records came with her.
She wasn't heavily modified but there were a number of little things here and there that I found;
ST185 front brakes
KYB Rally struts (seems to be on stock springs)
Cruise control gutted
Supra CT26
A valve working as a boost controller set to 10PSI - with the T-VSV line cut
Hella H4 headlight conversion
A 3" exhaust from the downpipe back, nice deep note to it
An HKS PFC F-CON sitting in the glovebox all hooked and doing...well, whatever it does
The paint on the hood has lost pretty much all its clearcoat due to engine bay heat, and the roof is pretty sunfaded. Found some evidence of a front end repair but everything with the chassis seems nice and straight.
In the last year I've done a few things, mostly for maintenance as the OEM clutch gave out on me sometime last October.
To correct that I picked up a Clutchmasters FX300 off of someone here, and did a nearly-complete Speed Source makeover:
Then after that I tended to some other issues, like the horn being so weak it couldn't be heard over the engine idling. So I fixed that, with a Hella Supertones horn set. :)
And because I don't like the OEM green lighting (plus a bulb was burnt out), I replaced all the gauge cluster lights with red LEDs to match the interior. Also went for the window switch lights too
Since that time I've also picked up the BGB's and EWD books for her, as well as gotten a full alignment and new set of Yokohamas to replace the very much dead Falkens she had originally.
My last bit of work up until now was installing a new boost gauge as the stock one doesn't read high enough...and after installing the new gauge I really did learn how slow the OEM boost gauge is!
Seems to draw about 9 in/Hg when cold and about 13-14 when warmed up, which I'm guessing is normal due to being at altitude.
This car has been a pure dream cone true for me, even despite the hangups of the HFH bursting and having the clutch give out. She's my DD and my latest addiction. I'll be doing more things to her with no solid goal in mind except making her into the best machine I can.
1988 Celica Alltrac
1988 Supra turbo targa
1997 RAV4 2dr
Dracov
Postby Denver_whiteST185 » Wed Jul 23, 2008 8:49 pm
those vacuum readings are a little low (considering thats my old boost gauge, and i lived in lakewood relitively close to where i think you work)
i would go through and start replacing your vacuum lines with some silicone and using small worm clamps to secure them. where are you tapping your vacuum source?
looks good though. i like the red gauge lights. you know, you can make the boost gauge light up red (not sure if you already did that, but its pretty simple)
^Ted^
Denver_whiteST185
Postby Dracov » Wed Jul 23, 2008 9:09 pm
Yeah, I picked up a red LED for the boost gauge so it matches.
Source for the boost guage is by the passenger side of the intake plenum where the stock MAP sensor gets it's vacuum source. The needle also reads at the high end of the zero range when everything's at rest so it could just need calibrating also.
Replacing the vacuum hoses is in a long list of little projects to do, just a matter of getting around to them. :)
1988 Celica Alltrac
1997 RAV4 2dr
Dracov
Postby Denver_whiteST185 » Thu Jul 24, 2008 1:21 am
before you start trying to calibrate it, i would do those vacuum lines. my vacuum readings increased by 2 in. hg. from just swapping from zip ties to steel worm clamps and redoing my lines with silicone...
^Ted^
Denver_whiteST185
Postby Dracov » Thu Jul 24, 2008 4:11 am
Never said anything about cracking it open and having a go. It's not a huge worry to me at the moment. I'll probably pick up a silicon hose kit after I get the new batch of toys in and installed
1988 Celica Alltrac
1997 RAV4 2dr
Dracov
Postby wakkjobb » Thu Jul 24, 2008 4:37 am
That is the first real live AT I ever saw. Have you replaced the IC radiator? I finally got my engine in, waiting for money to finish IC piping and all that goodness. And the other minor details like brakes and vacuum hoses. Yay! :twisted: :twisted: :twisted:
What?
Dan
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Dracov » Thu Jul 24, 2008 11:29 am
Yeah, I got the replacement heat exchanger on. It too seems to have a leak, but it's alot less than the old one...got a feeling it's one of the hoses trying to torment me since they were nearly impossible to remove in the first place.
Can't wait to see your 'trac up and running. :)
1988 Celica Alltrac
1997 RAV4 2dr
Dracov
Postby Dracov » Tue Jul 29, 2008 4:04 pm
Wonders never cease in their perrversion and strangeness. It would appear, beyond any reasonable doubt or coincidence, that the Alltrac has incurred a fluid leak. But, it's not oil (though there is that...it will be dealt with soon), nor fuel. Not the clutch line nor brakes, not even power steering or coolant.
Windshield fluid!
The stupid windshield washer fluid reservior has seemed to have cracked or develped a hole of some sort, leaving a nice half gallon puddle beneath the front right tire. I don't even want to think of the stupidity of this problem, much less the fun of acquiring a replacement, lest by some grace a 162 tank is identicle. At least it's not critical...I haven't used the washers in months literally.
1988 Celica Alltrac
1997 RAV4 2dr
Dracov
Postby LegacyofDan » Tue Jul 29, 2008 4:37 pm
i really like those Red LED'S, where did u pick them up at?
Postby Denver_whiteST185 » Tue Jul 29, 2008 5:03 pm
i would be willing to bet money that the FWD celica has the exact same tank. i wouldn't see why not...
^Ted^
Denver_whiteST185
Postby Autobot » Tue Jul 29, 2008 5:52 pm
My horn sounds like a dying baby duck. How much did those Hellas set you back?
Autobot
Postby Dracov » Tue Jul 29, 2008 6:02 pm
LEDs I get from superbrightleds.com, they have a very good selection, just about everything short of actual LED headlights. :)
The horn kit I got from rallyarmor.com, they were something like $55 at the time. They're nice and LOUD, 118dB with I think a very fitting tone for our cars
As for the washer fluid tank, I was mostly griping, I'll take a look at it later this afternoon. Chances are a 162 tank will fit if it comes to that. Otherwise I might just ghetto fix it and be done with it
1988 Celica Alltrac
1997 RAV4 2dr
Dracov
Postby Hotrodhendrix » Tue Jul 29, 2008 8:36 pm
RedCelicaTRD wrote:If it's just a crack you could do the ghetto thing and seal it with silicone. I've done it before 8)
I would do this before anything else. Its not like anyone will see the fix and you don't have to go through the trouble finding a replacement. My 91 alltrac tank matched to my old 90 gt coupe so you could probably just run out and get one of those at a junk yard.
Postby wakkjobb » Thu Jul 31, 2008 2:09 am
If you want, I can take a look at the one in that 88 GTS at my local yard Friday and see how it compares to our AT tanks; only thing is it has been hit in that area so it might be "Le toast", as the French say.
I too can't wait to get my AT running. I have dreams about it often :( Or :D depending on how you look at it.
Dan
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby wakkjobb » Sat Aug 02, 2008 12:08 am
The tank looks okay and both pumps are there, no cut wiring either. I hid it so it doesn't walk off before I go back there.
Sir Sneaky
Dan
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
