June 3rd update:
Still off the road. I've taken my entire dash out and am re-doing some grounds. I found some sensors from the old owner and some very sketchy audio wiring. My car has System 10 speakers, but an non-factory deck, so I checked out where that System 10 box would be under the passenger seat (it's basically a set of crossovers?). It wasn't connected, and the wiring harness going to it is looping back on itself to somehow allow non-factory decks to work. I want to clean this up soon.
Anyhow, I bought a stroker from RWDDragoon!!! Please don't hate. -> http://alltrac.net/phpBB2/viewtopic.php?f=15&t=31752
3S-GTE 2.2L MCS Build
3S block, torque plate bored, honed, deglazed, vatted, cleaned, painted red, assembled
5S crank destroked to 3S rod sizes, balanced with rotating assembly, micropolished
King Engine Bearings & Thrust Washers
CP 86.5MM forged stroker pistons, 9.0:1 compression, 020 over bore
Eagle H-Beam Rods
New OEM oil strainer, real seal & rear seal retainer
MCS New OEM Shimmed Oil Pump w/ front main seal
ARP Head studs
Cometic MLS HG
Greddy timing belt
OEM timing belt tensioner
MCS STAGE II Super Flow 3S Head
1mm OS Competition Plus Valves, keepers, locks, bronze guides, TI retainers
Dual valve springs
New HKS 272 camshafts
HKS Cam Gears
1ZZ Shimless buckets
New Toyota lower timing belt cover
New Toyota upper timing belt cover
New Moroso internally baffled oil pan
New Moroso Oil pan stud kit
This will go in this summer hopefully along with my SB46 turbo kit (might be a bit small for this motor, but we'll see), a KU Center Feed manifold, TVIS delete, Air con delete, ABS delete, Power steering delete and the fuel system and ECU, etc I have.
The future looks powerful.
Timmey
Eagle H-Beam Rods
ARP Head studs
Cometic MLS HG
Greddy timing belt
Dual valve springs
HKS Cam Gears
Timmey
