Phattyduck's SV25/ST205 hybrid
Re: Phattyduck's SV25/ST205 hybrid
Postby CTechBlueDragon » Tue Oct 27, 2020 8:02 pm
Hey man long time no talk. Maybe think about replacing the tensioner while your in there if its still apart. I still have my All-trac Camry but it sat for a long time because it jumped timing but still would run I couldn't figure it out. It took forever to find a crank angle sensor and then that didn't fix it. I had to move and after that I finally figured it out so its running again and I am about to put it back into service.Image
CTechBlueDragon
Images: 52
Postby phattyduck » Tue Oct 27, 2020 9:17 pm
CTechBlueDragon wrote:Hey man long time no talk. Maybe think about replacing the tensioner while your in there if its still apart.
The tensioner is definitely getting done. The OEM one is probably pretty reliable, but it has 10+ years and ~60k miles on it now... Not worth the risk. All the leaking parts (other than the PCV grommet) are original from '95, so no complaints there. I ended up getting brand new OEM cam/crank/oil pump seals to install. At this age, even if one isn't leaking I think its reasonable to do.
Aside from the smoke that's all over now, I bought and fixed up a 2000 Camry for my father-in-law over the last month... gotta get back on the Alltrac again!
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby phattyduck » Thu Nov 19, 2020 4:39 pm
So, turns out you need to remove the downpipe (!!!) to change the water pump due to a series of part inferences. AC bracket has to come off, which means AC compressor has to come off, but 3s-fe Camry AC lines interfere with the downpipe, so the downpipe has to move to get the AC compressor out of the way. Fun times. Didn't run into it before, because the last time I did these parts, the engine was out of the bay...
In other news, I started the oil filter relocation setup. New filter location:
I used two bulkhead NPT to AN fittings, which allows the filter housing to basically be directly mounted to the sheet metal.
I might need to put an extra shield up there, but we will see how it goes after a few thousand miles. The new location means I don't have to deal with removing the filter up in the engine bay and all the oil drips/spills that come with that. Just one pan, 0 special tools for an oil change. I only have to lift it up a bit since the car is lowered (drive up a 4.5" ramp I made a while back, really).
phattyduck
Postby autojumbled » Fri Nov 20, 2020 9:21 am
That's a neat install - looks good.
Where did the oil relocate kit come from?
autojumbled
Postby phattyduck » Fri Nov 20, 2020 4:43 pm
autojumbled wrote:That's a neat install - looks good.
This is how it looked originally:
I pieced it together, not a kit. The 90* take-off adapter is from Canton Racing, though Moroso has a better option now (uses -10AN o-ring fitting instead of NPT). All the hose is going to be -10AN push-lock from Aeroquip, with Aeroquip fittings (all black). The last version used -12AN blue hose and red/blue fittings (what was available at the time). The new filter mount is the cheapest billet option I could find.
I pieced it all together on Summit. The old lines were starting to have some cracks externally and weep a bit, so I figured I should change it all out before there is a catastrophic failure.
This is what I did on a Camry Alltrac BEAMS build, which I am emulating here (late gen3+ filter location):
Where the filter fittings come into the bay:
Take-off adapter, from bottom front corner of engine bay:
Hoses coming up in front of AC comprssor:
Hoses into filter mount (under cruise actuator, thus odd camera angle):
Suspension mount clearance (gen2 Camrys have an odd front suspension design with suspension mount where the filter would normally be):
I don't think this way can be done on ABS equipped ST185's, since the ABS actuator is there, right? But you guys don't have to deal with the suspension/frame rail issues up front...
phattyduck
Postby autojumbled » Mon Nov 23, 2020 9:23 am
Cheers for the detail.
and yes, that's smack in the middle of where all the ABS stuff is so a no-go for ST185 but there are a few options.
When I last looked at this a few years ago, the options were limited, as you say on the hardware - there's plenty more stuff available now so in theory should be fairly easy to put together. :)
autojumbled
Postby phattyduck » Mon Nov 23, 2020 4:10 pm
Ruined the phillips (errr.. JIC cross-head) screw on the water pump, and had to improvise. Luckily, I have some M6x1.0 button stainless screws in the garage. I had to modify the head a bit (they have a flange head) to fit in the water pump, but that gave me a chance to chamfer the rear to hopefully fit similarly to the original. Below - drilled out screw, modified bolt, original replacement bolt:
I am using the ST205 specific resin impeller water pump too instead of the stamped steel version. The one I took out also was a resin impeller and looked good after ~14 years and ~60k miles.
I also got the oil pump spaghetti seal and shaft seal replaced. I messed up on the first cam seal, but luckily I have some extras. Very nice to be putting stuff back on the car instead of taking it apart.
Slow progress...
phattyduck
Postby autojumbled » Mon Nov 23, 2020 4:27 pm
phattyduck wrote:Ruined the phillips (errr.. JIC cross-head) screw on the water pump, and had to improvise. Luckily, I have some M6x1.0 button stainless screws in the garage. I had to modify the head a bit (they have a flange head) to fit in the water pump, but that gave me a chance to chamfer the rear to hopefully fit similarly to the original. Below - drilled out screw, modified bolt, original replacement bolt:
Slow progress...
Has anyone actually removed the water pump without mangling that screw? I certainly haven't!
Sent from my Pixel 3 using Tapatalk
autojumbled
Postby phattyduck » Mon Nov 23, 2020 5:02 pm
autojumbled wrote:Has anyone actually removed the water pump without mangling that screw? I certainly haven't!
I did the first time... but the engine was out of the bay. The right sized JIS cross-head driver on an impact driver (the kind you hit with a hammer) would probably get it out just fine.
phattyduck
Postby CTechBlueDragon » Tue Nov 24, 2020 3:00 pm
I think most people run into this problem and blame it on the design. I had the same problem because when you take all the other bolts out and find the recessed one last it has all the pressure on it alone and it will strip out. The way I got it to come out was to have the surrounding bolts in still spreading the load across them evenly so the screw driver will get it out even without a hammer one. Good to see the progress man. The oil filter setup is way clean now. I put mine in the exact same spot actually! I will post some pics later.
CTechBlueDragon
Images: 52
Postby phattyduck » Mon Dec 21, 2020 4:51 pm
Got a couple more hours in on the Alltrac. I was having a ridiculously bad time with the cam seals. I had to buy two extras - my final score: 3 messed up, 2 successful, 1 leftover. Only $10-15 each... ugh. In the end, I used a de-burring tool to get rid of any harsh lip on the outer ring of the seal opening - that was where it was catching (even lubed and going in as straight as I could get it).
At least the crank seal went in fine. 2" PVC/ABS makes a perfect size seal driver for that..
After some struggle with the tensioner, I also have the timing belt installed, though I still have to check the mechanical timing after installing the bottom cover and main pulley (grenade pin NOT pulled yet).
phattyduck
Postby phattyduck » Tue Jan 05, 2021 9:13 pm
I got the engine work done last week (timing belt and new oil filter relocation).
Like I already posted, the filter now sits in the fender well instead of high up in the engine bay:
New -10AN (down from -12AN) lines were run (Aeroquip push-lock). The new take-off adapter uses o-ring seals instead of NPT taper fittings (less likely to leak/seep).
The lines run up over the frame rail to the bulkhead fittings that run back down into the fender well:
Once that was done, I took the car down to my buddy's shop to have it smogged. Before the smog check, we welded up the EGT bung as well as we could (the previous weld had cracked so there was an exhaust leak before the turbo - bad for performance and emissions).
I use a guy that make sure it passes everything other than visual (he even checks the gas cap still seals...). Sadly, it failed on idle hydrocarbons. The plan is to replace the O2 sensor (still original, ~25 years and ~100k miles old) and have the fuel injectors cleaned/tested. There was also an evap system leak to track down. Hopefully that gets things back in good running shape.
Then on to engine mounts, rear diff mounts, rear suspension bushings... and probably some other stuff I'm forgetting.
phattyduck
Postby phattyduck » Thu Jan 14, 2021 11:41 pm
I think I found the source of the poor emissions test results:
I'll be reinstalling them tonight... probably won't drive it until tomorrow - but I'll definitely be reporting back.
As for the O2 sensor, I used the 2nd gen motor one and soldered on the 3rd gen connector.
phattyduck
Postby phattyduck » Fri Jan 15, 2021 4:43 pm
I probably should have taken more pictures last night... but it is back together. I'll be testing it later today. (actually, I probably should have pressure tested it before I put all the intake and stuff back in the way, eh?)
Spiffy clean injectors:
Fuel rail parts:
phattyduck
