Just showing a few shots of what i got going. almost done, waiting to put the fuel rail back in with new o-rings, grommets ,etc. this is a parts list of what i've put in her: jdm 1st gen 3sgte
12 lb aluminum flywheel
f1 racing stage 2 carbonized kevlar clutch + PP
new release bearing
toyota flywheel bolts
new oem thermostat
new oem throttle body gasket
no EGR! but, retained EVAP
ngk plug wires
bosch double plats
goodyear gatorback timing belt
new turbo, oil and coolant gaskets
gutted downpipe
oem injector o-rings, insulators, grommets
new oem water pump
glow shift boost gauge...
what do you think my HP is after this?
i'd say maybe stock hp + 10-15
for now
i'll post some more as the progress comes
new release bearing
new oem thermostat
ngk plug wires
bosch double plats
gutted downpipe
new oem water pump
for now
