Progress has slowed a bit recently due to having to move house.
I need to solve this, will have the down pipe from the bypass lines cut off and a appropriately sized barbed pipe welded on:
A Moroso sump is a no-go for me at the moment, mainly because im concerned with its durability.
This car will go off-road fairly often, and i dont want to end up with a small sump hit cracking the alloy.
So, ive started modifying my gen2 sump using sections from a 5S sump.
The increased size:
Making up the pieces from sheet steel to fill the gaps:
#4
Pickup location... ill build a hinged baffle system around it.
