OKC Project-8/1/15-Another fun car!
Re: OKC Project - wrapping/looming up harnesses ideas?
Postby l0ch0w » Thu Nov 01, 2012 2:51 am
DR-25 is about the only thing you can use in terms of automotive heat shrink thats going to stand the test of time tbh...
Remember, the factory harness is in no way hermetically sealed.. have you ever seen the underneath side of your fusebox??? One theory is that you should allow it to breath freely as to allow humidity and moisture the opportunity evaporate rather than stagnate inside the wire housing... Either you hermetically seal your harness completely from the elements (which is very very expensive) or you allow it to breathe...
That and the flexibility of the wiring has more to do with how the wire is arranged inside the heat-shrink vs what kind you use...
For good flexibility in a harness you have to concentrically twist the wire and add strain loops before the connector... Like this:
I've torn apart my fair share of harnesses, and by far the biggest failure point on our engine harnesses is where heat from the exhaust manifold has damaged the insulators on the O2 sensor wiring, Alternator wiring, and A/C wiring... Once the insulators are damaged to that point, the moisture trapped in the harness wrap and heat cycling begin to degrade the conductors. For the most part everything else is left relatively unscathed...
Andrew
1991 Red Alltrac
l0ch0w
Postby Fox 21 Alpha » Thu Nov 01, 2012 4:58 am
I wouldn't get too wrapped up in the milspec requirements, after being in a HMMWV with an electrical fire, the "self extinguishing" part isn't all its cracked up to be lol. Can't complain too much though, it was contained long enough to get out and hit the flame with a extinguisher and save the truck.
Fox 21 Alpha
Postby l0ch0w » Thu Nov 01, 2012 3:43 pm
Were HMMWVs built to aviation mil-spec? I always thought their wiring was similar to any other vehicle's since they were made by GM. I know they have some ITT Cannon connections, but most of the other stuff was just regular automotive primary wire wasnt it?
Andrew
1991 Red Alltrac
l0ch0w
Postby Fox 21 Alpha » Thu Nov 01, 2012 5:48 pm
Couldn't tell you, I'd assume our military vehicles would be built with whatever "mil-spec" requirements were out at the time (it was somewhat new, atleast by Army standards lol), but then again that'd be using logic, and thats a no-no in the military.
Fox 21 Alpha
Postby toayoztan » Tue Nov 06, 2012 7:11 pm
Pics soon to come!
But just thought I'd drop by and say I've removed the harness for the ABS inside and engine bay (it's a TON of wiring).
I also removed the cruise control in the interior (the engine bay harness is part of the Engine Harness) with the speed sensor ECU. It thinned things out a bit too. I've removed the Cruise actuator years ago, and hardly use cruise in any car unless going across state (which doesn't happen in my alltrac, much). I need to remove the column switch/controls to clean it up there too.
Next, I'll be removing the clutch safety switch (A - Don't care for it or need it, B - I never park in gear, and C - I had an alarm that has remote start, but unsure if I'll put the same alarm back in...it was a bit fancy and had a bunch of wiring, including turbo timer, aux functions, etc...not really looking for that. I'd like an alarm that armed/disarm and remote started.). There's just one switch (at the clutch pedal) and a relay at the passenger junction box.
Only thing then will be to remove the rest of the AC. I kind of did this the hard way. I completely teased away the entire HVAC harness first. Probably would be easier to just start at the "ends" where the sensors/relays/etc. are, and just go backwards. However, I now know what I can remove for sure I believe, what to keep, and I'll be wrapping it as a separate harness in case I mess up - it isn't as wasy to "delete" as the ABS and cruise since a bit of the wiring is still needed to control the fan motors, switches, etc.
With hardly anything going to the engine bay now, I'll probably relocate the big relay box in the engine bay near the battery. Just unsure where to relocate it. I want easy access and if that isn't possible, I'm not going to sacrifice access for cosmetic tucking.
Since I'll have an EMS, I'll also be removing wires for the injector and fuel pump resistor pack, and whatever else I can find.
I'll try my best to post up "how to" remove all of these harnesses, but damn, it is a bit of work to even show that step by step. I'll post pics that show the main gist of things...and diagrams showing you what to remove and what you must not remove JUST because the diagram shows it - like stop switch, parking brake stuff, combo meter wire, etc. Otherwise, it's as easy as starting at the sensor/relay or any ECU that's available, and just tracing the wires and de-pinning them from the plugs. Also, might want to consider and just unwrap the entire harness up front instead of doing it as you go. It'll make the job easier and faster and more efficicent.
This is NOT an easy task, and I don't recommend it to anyone unless you plan to almost completely remove your dash and anything under/behind it. And you need to be comfortable with wiring. I'm not genius at electrical nor am I an electrial engineer, so I spent a bit of time reading up the wiring manual and studying the wiring diagrams making damn sure I knew what I was removing.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Fri Nov 09, 2012 3:15 am
Pics, b/c I know most of us like seeing that than readin posts :P
This is not an official How To, but briefly what I have done. I will try and make a proper How To on ABS, AC, Cruise Control, and Clutch Safety Switch removal later when I get more time over the next few weeks.
Here is where the ABS is located.
Passenger side removed.
Center section removed.
Driver side with most of harness removed.
This is what you'll mainly end up with when ABS is removed. The only wires going across the center is for speaker and door sensor.
That's a lot of wires for ABS!
Removed the entire dash harness to get to the rest of the ABS (only few wires), and start on AC and cruise.
Here's all the ABS components - ABS unit ("brick"), 4 speed sensors, ECU, and Accel unit (located above rear driver speaker).
Speed Control ECU (for cruise control) with its harness removed from the dash harness.
All that's left is the A/C and clutch safety switch!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: OKC Project - 11/8 - Bunch of wires removed!
Postby phattyduck » Fri Nov 09, 2012 5:07 pm
I suddenly feel so lazy for leaving all the auto trans wiring in the car when I did the auto->manual swap. :doh:
Its amazing how much extra goes into the car for 'creature comfort' and safety stuff...
Awesome work!
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby yota 3.0 » Fri Nov 09, 2012 6:16 pm
Nice write up!
Any idea of how much weight you saved?
Keep it comin :)
James
yota 3.0
Postby darthripley » Fri Nov 09, 2012 6:46 pm
I feel super lazy for just pulling the ABS ECU & not the interior portion of the wiring as well.
Once we tear into the car again I'll be looking forward to your How-To on it Bryan so we can ditch all the extra wiring that is unnecessary.
Great work on it!
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby jonstew » Tue Nov 13, 2012 1:04 pm
It's just my 2 cents but I would keep the A/C wiring in the car and make it so you can add the A/C back in at a later date; times and your attitude on it will change as you get older (well mine did and getting a little fatter didn't help). It's nice showing up at meets in the summer and all these guys that stripped their A/C out to save 60 pounds are sweating like crazy and looking at my All-Trac with envious eyes because the A/C still works. Once again just my two cents on the subject. Great build / restoration by the way.
~John Stewart
Indianapolis, IN.
'93 ST185
'88 ST162 (this car will run again....I think)
'02 Tacoma
'03 IS300 SportDesign
'02 Mercedes-Benz C320 Wagon (ole unreliable)
jonstew
Postby MWP » Wed Nov 14, 2012 2:39 am
Interior of the car & wiring looks soo clean.
Wish mine was like that, would make it far easier to work on.
[color=Blue]Daily:
Toyota RAV4 ACA23R
Race-Car: Toyota GT4 ST185 5S-GTE
Postby l0ch0w » Wed Nov 14, 2012 4:32 am
Seeing you pull your dash wiring harness is inspring me to do the same... But im definitely keeping the A/C... Ive had to drive a car without AC for like 3 years now... it sucks, I also LOOOVE cruise control. So thats not going either.
Andrew
1991 Red Alltrac
l0ch0w
Postby toayoztan » Mon Nov 26, 2012 5:57 am
Thanks everyone!
Jon, I'd love to keep the AC too, but I had the mechanical components ripped out 3 years go or so. The lines are pretty beat up. Realistically, if I were to have AC in an alltrac, I will probably end up getting another alltrac for track/street use and keep AC with it. That way, one will be dedicated for drag, another for track/street use.
Also though, when I rip out the AC wiring, I am going to keep the wiring and actually wrap it up into its own harness and throw it in the box with the other stuff, that way it can be hooked back up if I do change my mind.
I posted an AC deletion thread in Club Chat, so if anyone can help out with that, thanks!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Fri Dec 21, 2012 7:11 am
Alright, an update.
I'll try to keep the text short, and show you pictures instead.
Got done separating the cruise control, ABS, AC, and neutral/clutch safety switch from both the engine bay and behind the dash. AC components were already ripped out years ago, so I already know how much it sucks without it. But I survive and we don't get a genuine winter of snow and ice here in Oklahoma, so there's plenty of opportunity to drive in Fall and Spring especially. More than likely, I'll get another alltrac and keep AC and use it for track use (maybe a 205 by that time??).
I must say, it was definitely a challenge to do all this wiring removal, but in the end, I am happy with this decision. I learned quite a bit about the wiring of our car, locations of things and improved my skills on reading wiring diagrams and manuals.
So, after getting everything together the first time, including the dash, I ripped it all apart again to do this mini project. Now, the pics below show I got it back together again (i'm a pro by now lol), along with the rear speakers back in like before. Next, I'm putting the 'empty' blower part back in w/o the evap core, then the carpet, and rest of the interior panels and seats.
Then the put the rest of the door back together, along with radio, etc.
Pretty soon, I will probably hook up what I need to, in order to get the battery online and have the car powered so I can test out various stuff like the windows, door locks, and sunroof especially (god I hope I put that together right...). I washed my car after throwing in the sunroof, no leaks, so that's a good sign.
Enjoy!
Mesh loom and roundit 2000 loom. I used mesh at first...hated it. It wasn't feasible for me at the time to depin everything to get the heat shrink and mesh loom strung through, not to mention it frays so damn easily at the ends. Even using a hot knife/wire to make the cuts, you still have to expand the ends which ends up to fray still. So I went with roundit 2000, split loom. It's awesome. It's rated near 400 deg. F, abrasive/chemical resistant, etc. VERY flexible to work with, and curls in on itself up to 180 degrees at least. Secured it with some 3M Super 33+ electrical tape, and I am good to go (for the interior at least). I may switch things up once I get into the exterior, and redo my engine bay harness that runs along the front, and my AEM wiring harness.
Here's the AC wiring separated out, including the fuse box (the horn and fuel pump relay remain attached to the harness of course), AC Amplifier which is found underneath the evap core area (you need to leave the AC Auto Amplifier and AC System Amplifier intact). I am 99% confident what I have removed is what is needed to still have a functioning AC. I double checked 50x and had a few others look at the diagram.
New OEM-type windshield.
Here's how the interior currently sits. You can see the wiring and dash is back in.
This shows the wires running across the front of the rear passenger seats. If you remember, this was a huge harness b/c of the ABS. Now, it's just 3 wires - 1 for the door sensor, 2 for the rear speaker.
Polk Audio speakers installed. I had to shave down part of the plastic on the box that was sticking above the surface. Wasn't too bad with a wheel grinder. Crossover is screwed in place above the box, where the ABS ecu would have been.
Rear tweeter for the component.
Here, TWM short shifter installed with SpeedSource shifter base bushings onto a wet black powder coated base assy. Also, you can see the roundit 2000 loom going across for the mirror controls and ebrake sensor. The speed control unit for the cruise control is also gone, which sits under the radio.
Here, you can see the speaker box showing what's in the rear. Mmm...Stance suspension, Tremec transmission, and various other goodies for the LS1 you see - we are going to put this into my bro's 240z that you saw earlier, if you remember.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: OKC Project - 12/20 - Restart on interior install
Postby underscore » Fri Dec 21, 2012 8:00 am
After seeing all that I'm definitely removing the ABS wiring next winter.
Users browsing this forum: No registered users and 10 guests
