OKC Project-8/1/15-Another fun car!
Re: OKC Project - 12/20 - Restart on interior install
Postby rallygarage » Fri Dec 21, 2012 12:15 pm
This shifter looks different then my 1990 shifter I think. Am I right? If it is different is it better?
rallygarage
Postby toayoztan » Fri Dec 21, 2012 4:55 pm
I believe the 90-91 does use a different shifter assy/base. Stock, the 92-93 is shorter, however, if going TWM, i'm not sure if there's any other benefit.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Landon » Sat Dec 22, 2012 3:34 am
I just installed a TWM shifter myself. Very happy with the result.
EDIT.
My shifter has a different set up then yours. The ball of the shifter is set in a different bushing on mine. Do you have the stock set up there? Because I know TWM lists the shifter as 90-93. I think. Just curious.
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Postby toayoztan » Sat Dec 22, 2012 4:19 am
The only thing I got from TWM was the actual shifter, their spacers, and misc. bolts/nuts hardware.
Otherwise, I do believe you use your stock base assembly. I did notice that in the instructions, some of the steps/pics didn't apply, I imagine because it was if you had a 90-91.
If my memory serves me right, the stock 90-91 base is, in fact, different than the 92-93.
I had a 92 shifter (can't remeber if I sold it), that was the exact same as this.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby athousandleaves » Sat Dec 22, 2012 11:51 am
IIRC; Stock 90-91 is mostly metal, 92-93 is mostly plastic.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby toayoztan » Sun Dec 23, 2012 7:14 am
Carpet is in, finally!
I'm pretty satisfied with the color of the carpet...still would like a fresh replacement though.
Now, moving onto the front seatbelts, rear interior panels, rear seats, cd player, etc.
I need to hook up the battery soon and make sure things are working properly...
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby warracer » Sun Dec 23, 2012 7:32 pm
Such an awesome project thanks for sharing! I hope that one day I will be as skilled a you are! :D
____________
JDM ST185H A-Spec:
-50 Trim CT26 -BC Racing coilover
-Yonaka FMIC -Swift Spring
-3'' SS exhaust -Poly bushing
warracer
Postby toayoztan » Sun Dec 23, 2012 10:09 pm
Thanks! Biggest skill is just having patience and taking your time :)
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby polm » Mon Dec 24, 2012 4:00 am
WOW! The car is basically going to be brand new! Great job man, I wish I had the time, space and money to do this...lol Big props to you!
polm
Postby toayoztan » Mon Dec 24, 2012 10:33 am
Ok, so now I went back and looked through my pics of my white alltrac (92) when I first got it.
The shifter is different...so now I am confused.
What the hell do I have??
Here is the pic of the shifter you can barely see when I first picked up this car years back. I thought the 92-93 was the same, but apparently not...
UPDATE: Found these in my "spare parts" folder from the 92 alltac. You can see the shifter better here.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Mon Dec 24, 2012 10:43 am
So all the pics are on the same page, here's what I have currently (with TWM installed).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Mon Dec 24, 2012 10:56 am
However, according to our own website in the "shifter upgarde article," I have the correct shifter shown with the TWM for a 93 car...so now I am more confused...what was in the 92 white alltrac?? I'm pretty sure there's just a piece of information I am missing in all this lol.
So are there 3 different versions of the shifter...the metal one for 90-91 you see below on the right side in the pic...the 92 all plastic you see in my pic above...and the 93 half metal/half plastic shown above with my TWM?
90 to 93, what is the difference???
The 90-91 shifter has a metal assembly and parts came separately for replacing. The 92-93 shifter came as a full assembly with a slightly longer bottom shaft, reducing throw. The 92-93 shifter assembly is also plastic. You can replace the entire assembly or just the shifter if you are doing a 90 upgrade. Here is a pic showing the difference by Matt Crawley. The 92+ assembly is on the left, 90-91 on the right.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Tecker185 » Mon Dec 24, 2012 11:31 am
I've had a shifter from every year 90-93 and the 90-91 shifter assembly sits lower. I have no idea why but it does. That's why the TWM comes with spacers because if you don't it will bottom on on the floor.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby darthripley » Mon Dec 24, 2012 6:32 pm
i'll have to look through my project thread b/c the shifter i have in the car now came out of a CS so that may be one of the differences. :shrug:
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby toayoztan » Mon Dec 24, 2012 7:31 pm
So is the 92 shifter really all plastic like my old one then, and then switched in 93 to the half metal half plastic?
I thought TWM recommended all years use the spacers or it would bottom out. That's how it appears on mine also...there is some clearance, maybe I can se about removing the spacers and double checking if it's needed or not.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
