ok so ive been building a st184 for the past year. got about 95% of the parts that i want. i recently went through a brink of genius or maddness. depending on how you look at it. and was just wondering what your guys opinions are on it. im thinking about swaping the FWD to AWD...
so far in my build i have
5sfe block
3sgte head
hks valve springs.
hks cam gears
aem engine management
a "stage 3" turbonetics t3/t4 turbo
eagle forged con rods
je forged pistons .20 over
toga high velocity oil pump
800cc precision injection injectors.
cx racing intercooler piping kit
hks turbo timer
hks evec-s boost controler
toga main bearings and rod bearings
hux racing side feed intake manifold with ford mustang 5.0 throttle body
3sgte oil pan
3/8 aluminum fuel lines
oil cooler
fmic
varible fuel pressure regulator
obx fuel rail
im planing on getting
tial 50mm wastegate
hks 264 lift cams
fereria valves +1mm over
port and polish
tubeular 3sgte exhaust manifold
hks ssqv Bov
jaz 10 gallon fuel cell
aeromotive external fuel pump
75cc direct port NOS injection
and more i just forget currently
im planing on putting down 500hp down to the ground. so converting to a mr2 lsd or awd tranny will help keep traction. what do you guys think. i can get a awd tranny no problem. getting the other stuff maybe a problem
5sfe block
3sgte head
hks valve springs.
hks cam gears
hks turbo timer
3sgte oil pan
oil cooler
fmic
obx fuel rail
tial 50mm wastegate
hks 264 lift cams
port and polish
hks ssqv Bov
