krogers128":248lbx3c said:krazy2":248lbx3c said:krogers128":248lbx3c said:checked the circuit open relay and that is switching like it's suppose to be. the fuel pump relay is not bad itself, if i loop a wire in two of the plug ins (female end of the fuel pump relay plug) the car will stay running. in my non professional opinion, i think it's either the ECU not telling the relay it needs to be turning on, or the relay itself is getting no power. however the open relay is switching which would be providing the power right? idk i need help i just want to drive my car haha. :shrug:
I had to jump my Walbro at check factory connector to supply 12 continuous to pump.
wouldn't that mean its constantly running, or?
12volts constant with switch on. There is a sight that can tell you how to do it at the relay. (http://www.gtfours.co.uk/) under st165 modifications. Mine would drop to low and barely would idle. Walbro said the pump needed 12 v constant.
