purplecelicaGt4
New member
So my project is still active and working pretty decent for what it is.. Only a hand full of people knows how she works..
She is a sleeper, you wont ever see me breaking the speed limits but maybe in the future i would test it out with the new drag events..
Finally have a Mechanic thats worthy to do my dirty work if i cant do it myself..
So no rush i have taken my time to get to this point and i hope i can continue this little adventure for a while...
Engine
Arias Pistons 8:5:1 , 1 mm oversized pistons
Cometic 1.6mm Head gasket
Forged Rods
Sard 850 CC Injectors
Supra 255lph Wallbro Fuel Pump
Full Race ported head (By BHP Performance )
Adjustible Cam gears
Toda 288/304 8.5 lift cams - In Progress
3 Angle Valve Job (By BHP Performance )
ARP Head Studs
ARP Rod Bolts
ACL Racing Rod Bearings
Tvis Eliminated and match ported
TRD Plug Wires
NGK 8s
Intake Manifold Match Ported
TVIS Plate Match Ported
Gearbox / Mounts
XTD 10LB Flywheel
Arp Flywheel Bolts
Competition Clutch stage 5, 1420 series - In Progress
C-One Racing Diff Mount
Polly Mount Upgrade
Management
Power Fc and Datalogit w/ 3 Bar Map Sensor
Copilot Auto Tuning assist Software
WideBand sensor and PLX box
Turbo System & Cooling System
Brand: Borgwarner / IHI
Model: 51T-32
Compressor A/R: 0.70
Compressor trim: 54
Exducer 70.00mm; Inducer 51.3mm
* 360° thrustplate, dynamic seal,
Turbine A/R: 0.6
54.6mm x 62.1 mm.
Turbine trim: stage II
Flange type: standard T3
Turbo XS High boost Application Blow off Valve
3 inch Downpipe and Exhaust - by Barbados Muffler center
Skyline FMIC
Megan Racing Muffler
Stock Exhaust Manifold with T3 Adapter plate
Aftermarket 2.2 core Radiator
Mini Turbo Timer
Suspension/Wheels
Megan Racing lowering springs
KYB Shocks
18" Rims w/ big band
225/45/18 Tyres
Near Future Upgrades
Nozzs Turbo Top Mount Exhaust Manifold
Precision 6262 Billet turbo
44MM Tial External Wastegate
Near but not that near Upgrades.
These Should help me break the 600hp threshold
Custom intake Manifold
80MM Throttle Body
1000cc Top Feed injectors
Bosh 300LPH Fuel pump
Brake system upgrade
Maintenance Performed
New oil Pump
New Water pump
Slave Cylinder rebuilt
New Master Cylinder
New Hand Brake Shoes
New Brake Lines
Wheel Alignment
Rebuilt Power steering Pump
Rebuilt Alternator
Rebuilt Starting motor
New Ignitor
New Distributor
New Rackins and roddings
2 New Front Wheel Bearings
Genuine Brake Pads
Rebuilt Gear box w/ new Cones
Upgraded to Supra 255lph Wallbro Fuel Pump
De-Rusting the Gas Tank
New Fuel Filter
Trial & Error/Previous Upgrades i dont use anymore
Hks VPC - Sold
Super AFC - Sold
G-force Upgraded ECU - Sold
440CC Injectors - For Sale
550CC Injectors - Sold
Oil Cooler and Relocater Kit - Sold
ST202 Asperated intake Cam Shaft 9.0 Lift - For Sale
XTD Stage 3 Clutch Kit
HKS AVCR EBC - Sold
17 inch WRX Rims -Sold
Stock ECU - For Sale
86.5MM Bore Wiseco Forged Pistons - For Sale
Standard Rods - For Sale
Stock HP is 225HP at 220 torque
I have no idea what HP range i'm in but it feels crazy...
I usually get full boost around 3000rpm..
These cars could make up to 300hp easy with a free up exhaust and 15psi with stock internals..
I believe i have most of the ground work covered for reliability to make 400-550 hp if tuned well...Boost and tuning will determine that figure.. But to secure this i would like to upgrade to the new turbo thats been tested up to 900hp..
The fueling should be good up to 550 hp anything more than that i will lean out.. So the future i will be needing 1000cc Top feed injectors and new fuel pump.. Depending on if i can get on the track and have proper gas to run with.. If not it will be useless and i will stick to a maximum of 15-18psi on this crappy pump gas. But its good to know the potential
Any comments?
Engine
Forged Rods
ARP Head Studs
ARP Rod Bolts
TRD Plug Wires
NGK 8s
Gearbox / Mounts
XTD 10LB Flywheel
Arp Flywheel Bolts
Polly Mount Upgrade
Management
Model: 51T-32
Compressor trim: 54
Turbine A/R: 0.6
54.6mm x 62.1 mm.
Skyline FMIC
Mini Turbo Timer
Suspension/Wheels
KYB Shocks
225/45/18 Tyres
80MM Throttle Body
New oil Pump
New Water pump
New Master Cylinder
New Brake Lines
Wheel Alignment
Rebuilt Alternator
New Ignitor
New Distributor
Genuine Brake Pads
New Fuel Filter
Hks VPC - Sold
Super AFC - Sold
HKS AVCR EBC - Sold
Any comments?
