3tcpower":2cnl5so1 said:Love the new goodies for the trac. That pump looks really small.
MWP":2cnl5so1 said:Where did you get the milspec connectors from?
l0ch0w":8b378o6q said:It did seem really small to me, but I have a confession to make... I have giant hands that make everything look small
CMS-GT4":s7repubo said:I know for a fact alltracs are much harder to work on when you have big hands. Working behind the intake manifold with these tongues is a distaster.
MWP":s7repubo said:BTW... be careful with how you use that "milspec" connector (its not milspec, itll be IP66 or IP67 rated).
Those pins will be rated for less than 5A each which means you wont be able to connect a lot of the normal engine loom wires with it.
Injectors are around 1A each, so that should be generally fine. My concern would be power and ground - make sure you separate the grounds for sensors and high current stuff, and double/triple/quadruple them up as necessary. This is assuming that it only ECU signals going through the connector - watch for lighting and other circuits if you they are going through the connector.l0ch0w":4oq9fng0 said:CMS-GT4":4oq9fng0 said:MWP":4oq9fng0 said:BTW... be careful with how you use that "milspec" connector (its not milspec, itll be IP66 or IP67 rated).
They are rated at 4A per pin... which ones in particular require a 5A signal?
I had intended this mostly for the pins feeding the ems... and i didnt think that dealt with any high currents...
