St215 motor + st205 gearbox into St165 JDM build
Re: St215 motor + st205 gearbox into St165 JDM build
Postby MWP » Wed Oct 17, 2012 7:32 am
bmt wrote:So I should be able to put it into my top hose and run the bleed off to my original tank correct? My little tank can then be a ,(very), small header tank as well? If I can do it like that I will whip one up!! I guess the size is about 75mm dia and about 120mm high, a cone on the top to help funnel the air off. I imagine that the inlet and outlet just have to have a decent vertical gap between them to promote flow?
Youll see in the Milner photo quite a large bleed tank.
Im not sure exactly how large one should be :(
The most important thing is to have it above the highest coolant point in the engine bay, so air heads up to it, and cant return.
Higher up the better.
[color=Blue]Daily:
Toyota RAV4 ACA23R
Race-Car: Toyota GT4 ST185 5S-GTE
Postby bmt » Wed Oct 17, 2012 8:01 am
Yeah mine is definitely at the highest point, so that isn't a problem. The extra capacity, (Up to 4 litres!!), is there for more extreme motors, (or conditions), than mine I believe so I guess it will be ok. It is after all, over and above a standard set up so it cant do any harm.
bmt
Postby Gary ST165 » Thu Nov 01, 2012 3:35 pm
Found your project thread via GT4DC. Looking good :D
ST165 turbo 4WD
Gary ST165
Postby bmt » Sat Nov 10, 2012 3:49 am
MWP wrote:
bmt wrote:I installed a coolant swirl pot...
No you didnt. Youve made up a simple bleed tank.
A nice looking one though :)
A swirlpot looks like these:
So a bit more like this? :D
Added another inlet to my bleed tank for the air to go to. Man, cars are gluttons for plumbing once you add all the stuff I have!!!
bmt
Postby MWP » Sat Nov 10, 2012 11:02 am
Nice work :)
[color=Blue]Daily:
Toyota RAV4 ACA23R
Postby WarTowels » Sat Nov 17, 2012 5:59 pm
Wow, I've never seen a FMIC shaped like that. Really cool idea!
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby bmt » Mon Jan 07, 2013 6:48 am
Sorry been awhile, anyway update time!
Got my dash back from being recovered.
Really happy with it. Short length suede in black with red stitching.
With the gauges in place.
My upholstery guy couldn't guarantee that the suede would stay stuck down in the windscreen vent area due to the heat of the sun and the small contact area so i made up some slotted curved pieces of aluminuim and got them powder coated and screwed them in place.
No the screws aren't rusty! They are bronze coloured. I couldn't get black and I actually think they look quite good!!
bmt
Postby bmt » Mon Jan 07, 2013 7:02 am
Also been working on my bonnet. I needed to put some venting in it. I made these about a year ago.
They were to go in my original bonnet with those ugly vents in it, (see on the first page).
So I figured I can still use them in my new set up. Time to break out the cutting wheel!!
bmt
Postby bmt » Mon Jan 07, 2013 7:36 am
Vents installed temporarily cause of paint etc.
They look a bit square in the photo but they are tapered. You can see better here,
Here's a view from the back.
The hope is that it should allow the air flowing from the front out and take some of the heat from the turbo with it!
At least when I park up the heat can escape from under the bonnet, and the rain wont fall directly on my turbo if it's raining.
I dont know if thermal shock is an issue on a turbo but if I can avoid it why not?
bmt
Postby DeeCee » Mon Jan 07, 2013 8:42 pm
nice work. I've always wondered about the potential of thermal shock on the turbo with the 185 RC vent.
I will have to consider a beanie to introduce some protection.
Seems that I am also modelling my pipe routing from your layout as well. Keep up the good work :)
DeeCee
Postby Toxygene » Mon Jan 07, 2013 10:29 pm
bmt wrote:Oh I changed something.....
Before,
After,
Another view,
I just wanted something different. It came up on our version of ebay . If you dont know it's from a St162 Corona. I had the grille dechromed and painted it black as were the indicator lense surrounds. I saved a bunch of weight by getting rid of the pop up lights as a bonus.
I have plans for the bonnet including a colour change!!
I had made this suggestion to people here in the US as a modification to make and everyone thought I was crazy. Glad someone did it and showed just how damn sexy that can look. I don't get everyone's attachment to the flip up headlights. I look at that and say it looks much more luxurious, modern, and it should also be looked at as a performance piece as it will drop weight AND net you better light output than the sealed beams. Even converted sealed beams.
Will you go with an aftermarket HID kit? I would if I were you. Just don't get any blue colored HIDs.
Toxygene
Postby 801Alltrac » Tue Jan 08, 2013 1:14 am
:shock: it looks great man love the front end , like the hood vents too , and the dash omg I love it looks stockish
Great work
801Alltrac
Images: 13
Postby bmt » Tue Jan 08, 2013 7:51 am
Thanks for all the comments guys!!
Yeah DEE CEE I might invest in a beanie as well cant hurt to keep the temps down as well as protect the turbo.
Toxygene I will stick with stock lights until I get it all running sweet. Easy upgrade later!!
bmt
Postby Punknoodle » Sat Mar 23, 2013 10:12 pm
Any updates? Is the car running now?
Punknoodle
Postby bmt » Sat Mar 23, 2013 11:11 pm
Since I am getting my car wired at my work by my boss, and my other workmate broke his leg this meant the work piled up so my car got pushed to the back burner. Such is life!
I am trying to source some manual window winders and are also looking at removing the sunroof mechanism and bonding the sunroof in. I never use it and it's starting to rust so if I am gonna pull it I may as well upgrade it. There is a guy in poland that was selling fibreglass sunroofs, hopefully I can get in touch with him and source one.
Will update when I can, thanks for your interest!
bmt
