Something that has always bugged be about my engine bay is my power steering pressure hose in the right rear corner (my car is LHD) has never been secured as it should, as if the hose was too short or the steel line was tweaked. My engine is a gen2 JDM replacement and I've never suspected this to be an issue but Fri night I decided to look into it, unfortunately after I had already installed the engine
I measured my JDM and an extra USDM version I have and found that they are indeed different! The RHD hose was 3 inches shorter!
This may not matter to the majority of you but keep it in your back pocket for the future if you were to ever buy a JDM swap (for a LHD). . . Obviously, it will work but because it's shorter, the steel line will not secure to the body as it should.
