FC Zach's AllTrac
Re: FC Zach's AllTrac
Postby FC Zach » Tue Apr 14, 2020 12:30 pm
While I was elbow deep in this mess (as well as not having enough projects during this pandemic, so at this point I'm looking for things to fix), I thought I'd address the power steering pump leak I had accepted as "normal". . That and I would really like to park in the garage without a drip pan :) I placed an order for the reman pump before even considering removing mine to inspect/repair.
The part was scheduled to arrive yesterday so I started dismantling everything to remove my pump (man, they sure put it in a convenient spot didn't they!) and was able to get it out with very little fuss, I had more trouble removing the top (pivoting) bolt than anything else. Anyways, I got it out and immediately inspected the source of the leak which was a simple o-ring replacement. I swapped the pump anyways and decided to keep my core as a good spare or to sell in case anyone may need one in the future.
It's tight in there but really not that bad of a job. . Definitely better than the timing belt!
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Tue Apr 14, 2020 12:46 pm
Something happened during my cam seal replacement that I wish on no one. . while I was torquing the timing belt tensioner (hydraulic, not manual) bolts, instead of a gratifying click from the wrench, I got the dreaded feel of stripped threads on one of the bolts. Immediately assuming the worst and that I was going to have to remove the engine to gain access to repair the threads, I was actually able to do it installed. I had to use an adapter for my tap, if it wasn't for that I probably would have had to pull the engine. Kudos to the adapter, it definitely saved the day!!
For the inquiring minds, the mounting surface for the tensioner is thick, thick enough that Toyota should have used longer bolts for it. So with that said, if you strip a bolt, make threads and add a longer bolt.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby autojumbled » Tue Apr 14, 2020 1:20 pm
FC Zach wrote:Something happened during my cam seal replacement that I wish on no one. . while I was torquing the timing belt tensioner (hydraulic, not manual) bolts, instead of a gratifying click from the wrench, I got the dreaded feel of stripped threads on one of the bolts. Immediately assuming the worst and that I was going to have to remove the engine to gain access to repair the threads, I was actually able to do it installed. I had to use an adapter for my tap, if it wasn't for that I probably would have had to pull the engine. Kudos to the adapter, it definitely saved the day!!
LOL! This exact thing happened to me and is the reason my GT4 has not been on the road since November.
I was doing a cam belt change after it snapped and same as you, tightening the tensioner pulley when the wrench just went free!
I've gone overboard though and pulled the head off as my solution after I tried every trick in the book to be able to drill and tap it with the engine in place. Finally got around to it this Easter weekend and used a recoil kit.
The amount of effort it's taken just to sort this thread is infuriating!
Has given me a chance to clean up the engine and sort out other bits like snapped exhaust manifold studs etc...
Glad you manager to get yours sorted without ripping the engine apart!
Sent from my Pixel 3 using Tapatalk
autojumbled
Postby FC Zach » Tue Apr 14, 2020 4:09 pm
Oh wow! That's a lot of work for one (what should be quick and easy) repair! At least you got to address other things while at it. I'm very happy I didn't have to go this far!
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby warracer » Tue Apr 14, 2020 4:36 pm
I removed the PS pump from mine aswell, god I hated doing that haha , so little clearance with the engine tilted back.
____________
JDM ST185H A-Spec:
-50 Trim CT26 -BC Racing coilover
-Yonaka FMIC -Swift Spring
-3'' SS exhaust -Poly bushing
warracer
Postby FC Zach » Fri Apr 17, 2020 8:27 pm
I get everything in place and primed with new fluid, new belts installed too. . All this just to find that the pressure relief valve it stuck and the pump isn't doing anything, so I have manual steering for now. Always something! Now to find motivation to pull it apart again :roll:
On the bright side, no leaks :)
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby Magroo » Sat Apr 18, 2020 4:20 pm
Did you remove the ps pump without unbolting the ball joint and pulling the axle from the hub? If so I need to learn this black magic.
I rebuilt my pump last year and havent had a need to remove it since but every time I've tried either the tie rod or axle was in the way. I always found it easier to unbolt the ball joint and axle.
On a side note I finished my valve springs and valve stems seals without removing the head. First day took my 3 hours just to figure out the best method for using the tools. Seond day I got 2 and 3 done in about 3 hours. Last day I got 4 done and had it almost back together in about another 3 hours.
Of course I was off by 1 tooth on the crank my first attempt and getting the timing belt back on. Done this job like 8 times and I still haven't gotten it right on first attempt. :)
Magroo
Postby FC Zach » Sat Apr 18, 2020 4:36 pm
The best way I found to remove the pump (without following instructions in the manual) was to remove the tie rod end from the knuckle, turn the steering wheel full right, disconnect the high pressure line from the top, *remove the 12mm screw for the feed hose from the pump (have drip pan ready, this will make a big mess once you pull the line), and remove the vacuum advance thingy. Then the pump and hose will exit through the tie rod opening. Much easier than disassembling the ball joint and axle in my opinion.
Ha ha, nice! Yeah, this happened to me too. . No matter what angles I double and triple checked to ensure the gears were aligned to the head, it was still off and I had to take it apart again. . Which is likely why I had to repair the tensioner threads.
*Edit: forgot to mention this step I did.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby warracer » Sat Apr 18, 2020 9:48 pm
Congrats on no leaks !
I just deleted the PS since I hated enough removing the pump from the car...
____________
JDM ST185H A-Spec:
warracer
Postby sefiroxx » Sat Apr 18, 2020 10:02 pm
I do mine by removing the cross member and going straight down.
sefiroxx
Postby FC Zach » Sat Apr 18, 2020 10:15 pm
warracer wrote:Congrats on no leaks !
Well. . . For now LOL :) we'll see. Thanks though
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby FC Zach » Mon Apr 20, 2020 12:55 am
I pulled the replacement pump and checked what tech support suggested and no issue we found so I just sent it back as defective, I wasn't going to waste anymore time or fluid on it. . I reinstalled mine that I repaired with a new o-ring and all is well so far :)
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby Celicaatrac » Sat May 02, 2020 9:20 pm
FC Zach wrote:I pulled the replacement pump and checked what tech support suggested and no issue we found so I just sent it back as defective, I wasn't going to waste anymore time or fluid on it. . I reinstalled mine that I repaired with a new o-ring and all is well so far :)
That’s awesome!
Sometimes it’s the simplest things that fix a problem
Previously: celigts
Celicaatrac
Postby FC Zach » Thu May 28, 2020 1:16 am
I received and installed ATS Racing cam gears yesterday and I got everything buttoned up today. Ater a long joy ride, I really like the little gain from retarding the exhaust cam slightly. . It made a noticable improvement.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby FC Zach » Thu May 28, 2020 1:59 am
I also recently got a couple packs of poly bushings from a friend for the rear of a 185 (and possibly others) so with that said if anyone is interested in a pack I'll part with the other pack (one pack will do both sides).
1993 Yamaha GTS1000
FC Zach
Images: 9
