The corolla all-trac actually uses the same trans as the 1st gen Rav4's.
^ that is not 100% true. The Corolla's E55F or E57F uses different gear ratios then the Rav4.1's E250F. Secondly the bell housings are designed for the 4a engine setup hence smaller on the Corolla's gearbox then the Rav4's...which is larger and designed for the 3s engine setup. This leads me to the mounts: 3 of them, like most traversal Toyota layouts, have the engine mounts on gearbox and then 1 on the actually engine itself. 2 of those gearbox mounts (front & rear) bolt onto the bell housing. Because the Corolla's bellhousing is different then the Rav4's, they won't fit and will require fabrication.
So if you mount any E-series transaxle made for the 3s engine setup, eg E154F or E250F, it is not a direct fit and again will require fabrication.
Best Regards,
SXA10
Here's my swap...
http://rav4gtt.wordpress.com/
Best Regards,
SXA10
Here's my swap...
