Project ST165-ST205 Swap
Re: Project ST165-ST205 Swap
Postby Toyotawes » Sun Aug 30, 2020 5:45 pm
Beautiful car, has been inspiring looking through your thread. I got an 88 st165 last year and have been veeery slowly getting it back to where it ought to be. I got it from a kid who brought it here to OR from Colorado, and he bought it in Alabama. Quite the basket case.
Toyotawes
Postby zaluss » Sun Aug 30, 2020 9:50 pm
Toyotawes wrote:Beautiful car, has been inspiring looking through your thread. I got an 88 st165 last year and have been veeery slowly getting it back to where it ought to be. I got it from a kid who brought it here to OR from Colorado, and he bought it in Alabama. Quite the basket case.
Thanks man! Sounds like quite the project. Can't wait to see it.
zaluss
Postby mickeyfinn » Tue Sep 01, 2020 3:44 pm
Thanks for posting here Mike!
I'm never on Facebook. I follow your lead on a lot of stuff, so it's great when you post on this site.
Love the new exhaust!
I've got the same crappy ebay exhaust you had, and I don't really like it, so I'm looking for something else too.
I've been thinking about having the ST185 HKS Silent Hi Power exhaust custom bent installed.
Is that a straight Cat in your new system or a resonator/muffler? Would you share how much the new exhaust cost?
Thanks again for posting!
mickeyfinn
Postby zaluss » Tue Sep 01, 2020 3:46 pm
mickeyfinn wrote:Thanks for posting here Mike!
Straight cat. It wasn't a requirement but I wanted a cat for environmental and smell reasons :)
Exhaust was about $1300.
Exhaust clip
https://www.youtube.com/watch?v=4bQb4v0mmbw
zaluss
Postby mickeyfinn » Tue Sep 01, 2020 4:03 pm
I'm also looking to follow in your footsteps on the brakes...
So, 93' ST185 brake calipers will bolt right on without modification? Just need to get new rotors and pads?
Where did you get the calipers & rotors? Looks like they are readily available on rock auto?
mickeyfinn
Postby zaluss » Tue Sep 01, 2020 6:26 pm
mickeyfinn wrote:I'm also looking to follow in your footsteps on the brakes...
You'll need to trim the backing plate as well but yes it will bolt on with the carriers, calipers, rotors, and pads.
Unfortunately I can't tell you how they feel yet because I've run into issues.
1. The right caliper had deep groves on the brake hose face, causing brake fluid to squirt under pressure so I had to replace that.
3. Both calipers had terrible washers that didn't seal the brake hose ontop of that so I had to pick up Toyota OEM washers.
2. Both calipers have extremely loose brake bleeders, making it extremely challenging to bleed because fluid is leaking past the threads.
So basically these refurb calipers have probably been through the ringer too many times. Maybe find a nice used set and rebuild them yourself.
zaluss
Postby mickeyfinn » Tue Sep 01, 2020 8:26 pm
Thanks for the info!
Let us know how well the new upgrade works once you get things solved.
Where did you end up getting the rotors and pads?
mickeyfinn
Postby zaluss » Wed Sep 02, 2020 1:26 am
mickeyfinn wrote:Thanks for the info!
StopTech makes a nice kit that includes slotted rotors and street pads for the ST185. I bought them from PartsGeek because it was cheapest.
I would have preferred plain rotors but it was cheaper.
zaluss
Postby mickeyfinn » Tue Sep 15, 2020 6:17 pm
How is your brake project coming along?
If the ST185 Brakes bolt on to an ST165, I wonder if a Wilwood Brake kit would also fit? Last I checked, it seemed they made an ST185 kit, but not ST165.
mickeyfinn
Postby zaluss » Tue Sep 15, 2020 9:45 pm
mickeyfinn wrote:How is your brake project coming along?
I have the system all bled and ready to test but WA is currently covered in smoke so I haven't taken the car out to road test.
I believe a Wilwood kit for the ST165 can be had from Revolution Brakes but they don't clear 15" which is what I need. My OZ wheels didn't even clear them with the wheel weights :cry:
zaluss
Postby zaluss » Fri Sep 18, 2020 10:29 pm
Got the wheels back today all nicely powdercoated and straightened. I was going to order new decals but now I don't know becausse the plain look is pretty nice.
zaluss
Postby alltrac801 » Fri Sep 18, 2020 10:35 pm
Those look great! That's a hard choice plain looks really clean!
1991 Toyota Celica All-Trac White (239,000 miles)
1991 Toyota Celica All-Trac Black (163,000 miles)
alltrac801
Postby mickeyfinn » Fri Sep 18, 2020 10:43 pm
Damn! Those look great!
mickeyfinn
Users browsing this forum: Google [Bot] and 6 guests
