HOYS' ST185 Res-Q
Re: HOYS' ST185 Res-Q
Postby 93celicaconv » Mon Jun 11, 2018 3:35 pm
hoys wrote:Update!
Picked up an OE CS/RC hood and bumper.
Car will be getting a ST246 swap with FMIC. Hood should help the cooling situation.
The CS/RC hood is designed to remove heat from the engine compartment. Did you change the intercooler from air:air to water:air? If not, how are you cooling your turbocharged air charge to the throttle body?
93celicaconv
Images: 26
Postby hoys » Mon Jun 11, 2018 3:37 pm
FMIC = Front mount intercooler :)
hoys
Postby 93celicaconv » Mon Jun 11, 2018 5:39 pm
hoys wrote:FMIC = Front mount intercooler :)
That makes sense.
You are really modding your find there, Hoys.
93celicaconv
Images: 26
Postby hoys » Mon Jun 11, 2018 5:43 pm
That makes sense.
Finally found a car that I want to keep, so I'm putting money into it :)
hoys
Postby Soup84 » Tue Jun 12, 2018 1:44 pm
Congrats on the find! That's great looking '92 you got there!
1992 GT-S Celica - Daily driver
1992 All-trac - Beautifully maintained show car
1993 All-trac - Salvaged parts, RIP
Soup84
Postby crackerjack » Tue Jun 12, 2018 9:04 pm
Good barn find.
The clunking in the rear is probably the rear diff mount. Toyota wants lots of money for it but you can
get poly or OEM style diff mount from ebay and I have good luck with those.
Also, a note on timing belt for the Celica. removing the engine mount help tremendously and the website twosrus.com have studs you can buy for the tensioner and you can cut 2.5 hrs for timing belt change to maybe 1 hour.
when It comes to shocks, I lucked out with a full set of Koni yellow and HR springs at the local autowrecker 3 days after I found my Celica but alternative to that, I would say coilovers as shocks for the alltrac is non-existant anywhere as most shocks are for the FWD model.
cheers.
crackerjack
Postby Magroo » Tue Jun 12, 2018 11:45 pm
I've said it in other threads, but if you opt for BC coilover, get the swift spring upgrade. Its a night and day difference to the stock coil over springs.
And yes, the rear struts are almost non existent. I do remember a thread where somewhere in Europe they sell kyb? Rear struts for our cars. I dont remember exact details though.
Magroo
Postby 93celicaconv » Wed Jun 13, 2018 12:10 am
Magroo wrote:And yes, the rear struts are almost non existent. I do remember a thread where somewhere in Europe they sell kyb? Rear struts for our cars. I dont remember exact details though.
Here is the site: https://www.buycarparts.co.uk/kyb/824697
KYB 334-052 (rear right)
KYB 334-053 (rear left)
93celicaconv
Images: 26
Postby crackerjack » Wed Jun 13, 2018 12:59 am
I had the Excel-G for the front and the car was very bouncy. probably it was made for GTS where
it is not as heavy as the all trac?
I bought the KYB Excel-G before I got a hold of the Koni. so decided to try the KYB first.
crackerjack
Postby hoys » Thu Jun 21, 2018 10:25 pm
RC crash bar came in today. Good quality. Time to get the body parts painted now.
hoys
Postby hoys » Tue May 07, 2019 11:11 am
Test fitting RC/CS components. Going off to paint in a week or so. Will fix the roof clearcoat damage at the same time.
Also bought some cheap Avid 1 wheels for maximum scene points TM.
I think next on the list will be installing the RC intercooler and buying some coil overs as the suspension isn't getting any better.
hoys
Postby hoys » Wed Jun 19, 2019 11:51 am
Car is back from paint:
I've got a few more bits to fit onto the car and it should be ready to rock. Very happy with the result. No more clear coat fade on the roof!
On to fitting the air to water intercooler and new struts and springs all around.
I think after that I won't do much to the car for awhile. Probably start a long running engine build.
hoys
Postby hoys » Thu Oct 10, 2019 11:51 am
Drove a few hundred miles for a small car show. Car had no issues whatsoever. I'm starting to hear a noise that sounds like the turbo going bad and the clutch take up point is getting pretty high. So I guess it's time to swap :)
hoys
