abeans st185 - Kill 1 Save Another
Re: abeans st185 - Kill 1 Save Another
Postby Magroo » Mon Jun 15, 2020 8:28 pm
Yes you'll have to press out the hub to get the studs out. I used a hub puller like this one. https://www.amazon.com/Heavy-Duty-Drum- ... 151&sr=8-5
Inner and out hub seals are the same as front inner. Can usually find them pretty cheap on rock auto.
Radiator fan turns on via the fan switch located near the ac compressor. If its unplugged the fan will stay on all the time.
Magroo
Postby underscore » Mon Jun 15, 2020 8:32 pm
If the A/C pressure switch or the rad temp switch are missing or disconnected the fan will run all the time. The AC switch plug can be jumpered, the rad switch needs to be working or you'll overheat.
Postby abeans » Mon Jun 15, 2020 8:53 pm
Magroo wrote:Yes you'll have to press out the hub to get the studs out. I used a hub puller like this one. https://www.amazon.com/Heavy-Duty-Drum- ... 151&sr=8-5
Yeah, I got a press. It's a strange design these studs holding the backing plate on.
Thanks for the info on the seals, I forgot to order those with the bearings.. Doh!
underscore wrote:If the A/C pressure switch or the rad temp switch are missing or disconnected the fan will run all the time. The AC switch plug can be jumpered, the rad switch needs to be working or you'll overheat.
Cool, I'll have another look by the a/c compressor do you know which pins need jumping?
Thanks.
1990 St185 Celica
@abeans07 i post car stuff
abeans
Postby underscore » Mon Jun 15, 2020 9:54 pm
The switch would've been on the hardlines, near the firewall. It should be a 4 pin plug.
Postby abeans » Mon Jun 15, 2020 10:05 pm
underscore wrote:The switch would've been on the hardlines, near the firewall. It should be a 4 pin plug.
https://imgur.com/a/Hg7IMvk
Guessing this guy? Also I'm guessing this is my switch connector... I have no memory of that switch on either car. Might need to buy one.
1990 St185 Celica
abeans
Postby abeans » Tue Jun 16, 2020 12:58 am
Rear knuckle and press doesn't work great. Made a custom tool. Call it Toyota sst 0011-1234567
https://imgur.com/a/VBZs57Q
Works very good.
1990 St185 Celica
abeans
Postby underscore » Tue Jun 16, 2020 4:41 pm
Yeah the plug in that second connector looks the same as the one on my car that I had to jumper.
Postby abeans » Tue Jun 16, 2020 8:01 pm
underscore wrote:Yeah the plug in that second connector looks the same as the one on my car that I had to jumper.
You wouldn't happen to know which pins?
1990 St185 Celica
abeans
Postby underscore » Tue Jun 16, 2020 9:20 pm
According to my notes the light blue/black stripe & light green/black stripe wires. I made a little jumper to stick in the plug and then wrapped it all with a bunch of electrical tape.
Postby abeans » Tue Jun 16, 2020 11:20 pm
Thanks
1990 St185 Celica
abeans
Postby abeans » Tue Jun 23, 2020 10:44 pm
Ditched the Motegis for a set of 17x8 +35 Drag wheels . 245 40 17 Indy 500's. Looking pretty meaty.
Reading on the forum these are supposed to fit. I'm a bit concerned about the front, and i got 5mm spacers for the rear to clear the strut.
1990 St185 Celica
abeans
Postby sefiroxx » Wed Jun 24, 2020 2:36 am
abeans wrote:
- Radiator fan runs all the time. That could be for the above issue or possibly the A/C being disconnected? Looking online i see a 'radiator fan switch' in the radiator... pretty sure my Mishimoto radiator does not have a spot for that, nor do i recall one on the OEM radiators on either car... So i wonder what i'm missing.
My Mishomoto has a mounting hole for the temp switch. It came with a plug.
sefiroxx
Postby abeans » Wed Jun 24, 2020 2:38 am
Yeah it's there I am just blind.
1990 St185 Celica
abeans
Postby abeans » Thu Jun 25, 2020 11:25 pm
Well radiator fan won't kick on by it self...New radiator fan switch installed. Plus jumped the a/c plug.
Got a brand new gauge cluster temp sensor too. Also doesn't work (f me right)
https://youtu.be/lbzMIwkjya8
Got any suggestions?
1990 St185 Celica
abeans
Postby Magroo » Fri Jun 26, 2020 12:24 am
There are two temperature sensors on the water neck one is for the ECU the other is for the gauge cluster. The one for the gauge cluster is basically just a spade connector. The one for the ECU is your typical Sumitomo connector.
Magroo
