Project Magroo?
Re: Project Magroo?
Postby Gert » Mon Jul 13, 2020 12:37 pm
Thanks.
Searched for the part number # 89545-48020 and at Toyota it is very expensive. So problably this Ebay item is coming from Ali in China.
My experience with Ali parts are sometimes good and sometimes not.
Ordered some antenna masts from ali, but the plastic piece was a few mm too thin, resulting in a non functional in- and extracting antenna.
Then an Ali rearlight switch (on top of the gearbox). The switch did fit, but was slightly smaller, resulting in an always activated back light. Tweaking the switch tackeled the job.
But, since you tell us this ABS part is working fine, no problems to be expected. Thanks for your info.
Gert
Re: Project Magroo?
Postby psipwrd » Sat Aug 01, 2020 4:56 pm
Hey Magroo,
Good to see another alltrac, especially with similar setup and MSPNP2 93-95! Keep at it, to see that you're "almost done" is inspiring!
ImageEuro-Spec ST185 CS in Las Vegas
...still working on it...
psipwrd
