Project Lazarus: Pulled from the Ground; Save from the Grave
Re: Project Lazarus: Pulled from the Ground; Save from the G
Postby simple » Sun Jan 03, 2021 2:24 am
Nice!!!
simple
Postby Tippo » Sun Jan 03, 2021 7:18 pm
Hit a snag... all the lines are toast in the rear. I swear Tecker is a savant (which sucks for me). All brake lines, all fuel lines are 100% toast in the rear. Super annoying. Either way, gas tank install is on hold until I get all new lines. Is there anywhere to purchase pre-bent lines? I know you have to modify them slightly still, but something go off of would be nice.
Here's the current situation (in extremely high contrast):
It looks alarming, but keep in mind, the contrast shows extreme rust.
92' SW20 MR2 Turbo 742 Aquamarine Pearl - 4th Gen 3SGTE Swap
92' ST185 749 Teal Metallic - Project "Pulled out of the Ground"
90' ST185 182 Graphite Metallic - SOLD! Wish I never did.
Tippo
Postby Tecker185 » Sun Jan 03, 2021 9:21 pm
I purchased the last set of pre-bent lines in the states back in like 2009. Good luck routing them in the stock routing. Even using NiCopp lines I wasn’t able to make it look oem without kinking. Best of luck to you
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby Tippo » Sun Jan 03, 2021 9:41 pm
Tecker185 wrote:I purchased the last set of pre-bent lines in the states back in like 2009. Good luck routing them in the stock routing. Even using NiCopp lines I wasn’t able to make it look oem without kinking. Best of luck to you
Bruce ya frickin' jinxed me lmao (kidding). I looked a little bit today, that stock routing area looks like a PITA and yeah, there's no sign of pre-bent lines hanging around anymore. There's some guys in my area that will do it, but it's not going to be cheap if I do. I was thinking about buying braided where I can and then running it in a non-uniform method to the best of my ability. I got a few more phone calls to make though clearly lol
Tippo
Postby Tippo » Tue Jan 05, 2021 3:00 pm
At least the tank looks good lol
I contacted a local guy who bends NiCopp pretty frequently, I don't trust my own skills on this, as I feel I would be kinking way too much. Time to call in the professionals lol.
Tippo
Postby Tippo » Thu Jan 14, 2021 2:42 pm
So I scheduled the brake line install. I'm looking to order NiCopp brake lines, but the threads are confusing my search. Half the forum threads say 3/16, the other half say 1/4 brake lines with m10x1.00 connectors. So, which is it for a ST185? To be clear, I'm swapping out all the old steel coated brake lines for NiCopp - front to back. Ordering 50' unless I need more. For fuel send, I see some people saying 5/16 M14x1.5. Can anybody for sure confirm these numbers?
This is the best reference I found in a thread from 2015 from athousandleaves:
For my 185 I replaced the stock rear lines with the following after carefully measuring the original lines:
Brakes 3/16" M10x1.00
Fuel Return & Evap 1/4" Bubble flare (evap line may have had M14x1.5's?)
Fuel Send 5/16" M14x1.5
All working and no leaks... 165 should be similar.
In hindsight I should have just deleted the whole evap line too :bangshead:
Any help would be appreciated!
Tippo
Postby Tippo » Mon Feb 22, 2021 6:43 pm
So just a small update. I put the car up on a friends lift and started at the lines with him. The previous post dimensions were incorrect. Turns out the lines up top front are 1/8" and 3/8" ???? either way, had to postpone because I actually broke my hand taking the car off the trailer - took a few weeks to heal lol. Hopefully I can get this Lazzy running soon. The line routes are an absolute PITA.
Oh also, I got her some new shoes.
Here are some photos:
Tippo
Postby transneptunian » Tue Feb 23, 2021 11:27 pm
Awesome story man. Can’t wait to see more!
1993 JDM ST-185 - The project
1999 Dodge Ram 1500 - The tank
2017 Dodge Caravan - The grocery getter
transneptunian
Images: 17
Users browsing this forum: No registered users and 8 guests
