A little backstory on the car, I bought this 92 Gt-Four RC back in 2012 when I was young and stupid and didn't realize the true value of these cars. I had another Gt-Four A at the time, that was always broken and taking up all my money. So I parked the RC in the garage and started taking it apart with the idea of building something with it, so now it's on jack stands fully striped ….fast forward to December 2019 I sold my Gt-four A and now I can finally start restoring my Gt-Four RC. The car has been on jack stands since 2012 in my garage, only some surface rust underneath and some dents here and there but otherwise the body is pretty mint. So as of now my goal is total resto-mod project.
So I started the work winter of 2020, in my free time at night and a couple hours when I can on my days off, I’ve been doing everything myself . So far I have por15’ed the underside and wheel wells. Refurbished the gas tank in and out with por15 products. Powder coated everything I can, front and rear control arms, steering knuckles, rear diff. the rear sub frame was painted with por15 as I it doesn’t fit in my powder coating oven. Almost all the bolts will be getting zinc plated with Army grade Green plating. New brake lines to the back, I'll also have new AN6 SS braided fuel/return lines
I have a lot of work ahead but I’m fully committed to getting this car finished. I’ll post updates here, but I also post everything on my Instagram ( @milo_gt4) .
Here is the parts list so far:
GT4racing poly bushings all around , Poly front end links and their steering rack poly bushings
Xiiimotorsport rear subframe bushings with the solid diff plate
Whiteline rear swaybar
Racing beat rear endlinks
New bearings all around
SS braided brake hoses
ST205 Rear Brakes with new OEM rotors
Porsche 986 front Calipers
312mm Front disk(haven’t purchased yet but will eventually)
Feal 441+ Coilovers with swift springs
J-Speed rear strut/floor bar
TWM short shifter
dodge neon front strut bar
My goal with this car is to have a fun/reliable street/track/autocross car. When I get to the motor, I’ll be aiming for the 500awhp. I already have a 3rd Gen 3sgte that I will build. If all goes to plan the car will be back on it’s wheels before the snow. Then paint in the spring then I’ll start building the motor. The car should be ready for summer 2023, again if all goes to plan lol.
Here are some pictures . find it easier to just share a drive folder then to post pictures here.
https://drive.google.com/drive/folders/ ... sp=sharing
TWM short shifter
