Wanted: supplier for shock absorbers for ST65 Celica
• Page 1 of 1
I thought this task would be simple, but it isnt over here in Europe! Does anybody by chance know, where I could buy new shock absorbers for my ST165, original or aftermarket - doesnt matter? An Online shop with the opportunity of shipping to Austria would help me a lot...
I found those part numbers from Toyota, but couldnt find any shocks...
front
right: 48510-20392
left: 48520-20382
rear
48530-20180
Thanks for your support!
Thomas
front
right: 48510-20392
left: 48520-20382
rear
48530-20180
Thomas
1989 ST165, black
iTV - Club Member
Re: Wanted: supplier for shock absorbers for ST65 Celica
I think KYB was the last remaining company that made OEM fitment rear dampers for any Alltrac, and they were only sold in Europe. It's been a while since I looked for them though so those may be gone as well.
The fronts are just damper inserts so you can get those from KYB and a few other companies, there are also threads on here about other dampers that unofficially fit. Converting to inserts for the rear may be your best option too. You'll need a competent welder and a spare set of fronts off any 4th or 5th gen Celica to do it, or a machine shop to make up to pieces.
Ceika makes coilovers for ST165. I have them on mine. I think they ship worldwide too.
The owner of the company owns his own ST165.
I'm not sure I would recommend them. They are Extremely Stiff. I even replaced my springs with softer ones. It's still almost Kidney damage when I drive.
I'm looking to get better coilovers someday
- mickeyfinn
You could also do a conversion on the rears to accept inserts. I bought these made by someone else using Ground Control but it can be done if you know how to weld.
https://www.y8s.com/celica_gone/suspension.html
- zaluss
Zaluss, You HAD Ceika coilovers to, right? What's your opinion of them?
- mickeyfinn
mickeyfinn wrote:Zaluss, You HAD Ceika coilovers to, right? What's your opinion of them?
Same. Too stiff and was touchy to adjust camber which is why I sold them.
- zaluss
• Page 1 of 1
