Fuel tank hanger brackets and 2nd gen exh manifold
Postby BlackCat13 » Mon Dec 07, 2020 8:03 am
As title says i cracked.my mani and broke both brackets that bolt up next to the rear diff in my 185 CS
Any one got this stuff in the EU?
BlackCat13
Re: Fuel tank hanger brackets and 2nd gen exh manifold
Postby mickeyfinn » Wed Dec 16, 2020 5:22 pm
I think you can have the crack repaired by welding.
I have 2 ST185 Exhaust Manifolds. Both are cracked in the same place. I'm having them welded to repair the crack.
I also successfully had a crack repaired on my Exhaust turbine housing.
Maybe look into it.....
mickeyfinn
Postby Gert » Thu Dec 17, 2020 6:06 am
Gert
Postby BlackCat13 » Thu Mar 04, 2021 5:46 am
I welded everything, i seem to have a crack on the turbo side face aswell but on the inside hopefully everything holds
BlackCat13
Return to Parts Wanted
