WTB: ST185 Door moldings
Postby conor2469 » Fri Jun 04, 2021 12:04 pm
EDIT:
I got what I needed, thanks
conor2469
Re: WTB: ST185 Door moldings
Postby simple » Fri Jun 04, 2021 6:10 pm
If that part is on a GTS also I can probably get you that
simple
Postby conor2469 » Fri Jun 04, 2021 8:28 pm
simple wrote:If that part is on a GTS also I can probably get you that
Hey,
Are the door moldings the same on non widebody cars? I've seen 2 different types of molding, a wide molding and a narrow molding. Lots of narrow body cars seem to have the narrow moldings. The moldings on my car are 0.4" (5 cm) tall
conor2469
Postby simple » Fri Jun 04, 2021 10:28 pm
I got a full set of red wide body mouldings. pM me
simple
Postby conor2469 » Sat Jun 05, 2021 1:24 pm
simple wrote:I got a full set of red wide body mouldings. pM me
PM'd
conor2469
Postby Alikazam » Sun Jun 06, 2021 2:32 am
Hey,
Ummm... 0.4" = approx 10mm. Not sure how you get 5cm from that...
1990 Celica Alltrac - Emma
Gen 3 engine
KO Racing Street Brawler - Precision 5130 Turbo
KO Racing In Factory ECU Case - Link G4x ECU
327 AWHP @ 18psi - pump gas
Alikazam
Postby conor2469 » Sun Jun 06, 2021 4:29 am
Alikazam wrote:
Hey,
Correct! I put the wrong value in the converter. Thanks for flagging that.
5CM = 1.96"
conor2469
Return to Parts Wanted
