ST185 Speedo/tach gauge faces
amx
New member
I have a ST185 gauge cluster with the gauge faces from a GT-S which are 10mph and 1k rpm short. This is probably a long shot, but does anyone know of a source for these? Or a printable high-res scan?
So just your gauge faces are incorrect? The speedometer & tachometer mechanisms behind the gauge faces are correct for an ST185?
amx
New member
Yes, long story short I have an original ST185 cluster with 160mph speedo/9k rpm tach, but missing the faces for the speedo and tach. I swapped them over from a GT-S cluster I had as a donor, but was hoping to find some replacement faces that are actually factory correct for the all-trac.
Top
