[How to] Remove gauge cluster and repair faulty tach
Re: [How to] Remove gauge cluster and repair faulty tach
Postby Corey » Mon Apr 20, 2015 12:58 am
Removed my rev counter today. This is what I found. New caps from digikey are on their way. I'm also replacing the bulbs in the cluster and hvac while I have it apart.
26 year old revcounter with 157K km on the clock.
Note the damaged capacitor on the right is missing the same markings as the undamaged one on the left. I don't see any branding, specs or polarity markings on it. The only thing they have in common with each other are the blue wrap and the orange 904E marking (not sure what that indicates).
I'm going to install the new capacitors using Nubkin's photo as a reference for the polarity since one of my caps has no markings.
Corey
Images: 50
1989 Toyota Celica
Postby yyonline » Mon Apr 20, 2015 3:02 am
The triangle logo on the one capacitor is a very old Panasonic logo. I also see the marking KG which is a discontinued series of Panasonic capacitors.
904E is a date/lot code. Older Panasonic caps used red lettering for the date codes. I'm not quite sure how to decipher that as it doesn't seem to follow the same system that modern Panasonic capacitors use.
yyonline
Postby Corey » Thu Apr 23, 2015 1:44 am
Replaced both capacitors this evening, went for a test drive, seems to be working properly again.
I managed to replace them without removing the gauge dial/needle - just need to be careful not to get oily fingers on the gauge face because it will leave marks which can be tough to clean off.
Thank you Nubkins for the great writeup and to yyonline for the digikey link for the proper capacitors.
Corey
Images: 50
1989 Toyota Celica
Postby TheNubkins » Thu Apr 23, 2015 3:34 am
So glad to hear the repair worked out for you! And what a good idea keeping the gauge face in place! lol. Nicely done!
The Nubkins
-1990 Toyota Celica All-Trac Turbo
-2001 VW Golf TDI
TheNubkins
Postby Sifu » Thu Apr 23, 2015 1:54 pm
This thread needs to be stickied.
1990 Celica ST185 "The Money Pit"
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Brad_91 » Thu May 19, 2016 5:01 pm
Thanks for the write up!
I just swapped out my whole tachometer dial with a functioning one instead of messing with the capacitors in the original. I can attempt to fix my spare cluster now as a project..
Would have taken a lot longer to pull the cluster out the first time without this easy step by step! :notworthy:
Brad
1992 Celica GT-Four
~65'000km,
Mods: Turbo-back 3" Exhaust, 17x8 Versus Turismo Rims, Black Rally Armor Mud Flaps, turbo timer, manual boost controller, Whiteline rear swaybar!
Brad_91
Postby CMS-GT4 » Sun Jan 06, 2019 3:01 pm
Thanks for doing this writeup, it seemed to fix my issue. I was able to do the new capacitors without taking off the needle and face, but it was a pretty tight working condition.
92 st185 (205 swap) | 12 ISF | 13 Pilot | 17 Mazda3
linktr.ee/ColdironWorks | www.coldironworks.com | http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=19891
Postby shadow_coupe » Thu Aug 29, 2019 4:52 pm
TheNubkins wrote:Hopefully this helps someone out there.
Another shoutout to TheNubkins for making this write up, flawless instructions and thorough pics. Making this comment to show it's still a relevant issue and that the search function indeed works ha.
1990 Celica AllTrac
shadow_coupe
Postby gt4me123 » Mon Apr 18, 2022 1:31 pm
Great how to guide. Been recommending this for years when people have mentioned that their tachos have died. Agree with others that separating the dial from mechanism isn’t really a necessary step and cuts out a lot of extra hassle
gt4me123
Postby supra-raleigh » Tue Aug 23, 2022 9:42 am
I think that the following post of mine will benefit those who are reading this thread;
"Update.
Now I got my CHECK ENGINE light back! And, while I was at it, I fixed my slow/non-reading tachometer!! I removed the guage cluster using the following link: viewtopic.php?f=49&t=48848
I took the light for the CHECK ENGINE out of the back of the guage cluster and applied voltage via a 9 Volt battery. At first it did not turn on. I then applied pressure and squeezed the top of the bulb firmly into the black base and the light came on.
Two top tips..
1. Avoid Stripping Screws And Theads: Removing the guage cluster requires the removal of many screws that are more that willing to strip out both the head of the screw and the female threads that they are screwed into. Therefore, I used my small 3/8 drive right angle Milwaukee impact wrench with a 13mm socket and a SLOTED screw driver forced into the socket with a pressure fit. I made sure the slotted screw driver fit snugly into the top of the phillips screws. I put some of my weight into it so the slotted screw driver would not strip the screw heads. Then I slowly pulled the trigger on the Milwaukee and the screws one by one all gave in and started to loosen.
2. The Metal Retaining Clip: The driver side vent by the fog light switch has a trapazoidal knob attached to the rod that moves up and down so as to open and close the vent behind it. The knob is not too difficult to remove it just pulls out with some force. However, I again overlooked the metal clip that slides onto the rod and retains the knob. It is easy to overlook because when you put the panel back on that goes under the knob, the part of the panel in which the rod goes up and down in pushes the metal clip further down the rod. And when go to put the panel in its proper position and screw it down, you then go to put the knob back on and notice that it will not fasten itself to the rod because the metal clip that is supposed to retain the rod has been pushed back about an inch as you were putting the panel in place.
Next, I removed the panel again and I had to use some PB Blaster and two angled pliers to remove the metal clip from the rod. I took alot of force and when the clip did slide off, it flew off as soon as it was free from the rod. Luckily, it landed inside my shirt. I then reinstalled the panel and when everything was in place, I put the metal clip on the end of the rod and pushed it down the rod until it was flush with the rod. I then was able to put that trapazoidal knob securely back in place.
I said "I again overlooked" because I made the same mistake sometime in the late 90's on my 1991 Celica ST while I was installing a set of Indiglo guage faces which are still working on the car. But this time I figured it out that there is that metal clip that is supposed to retain the knob.
I am sure that many of us made this error so here is the solution. I hope this helps someone out."
none
supra-raleigh
Postby yyonline » Sat Aug 27, 2022 1:39 am
supra-raleigh wrote:I think that the following post of mine will benefit those who are reading this thread;
Get a JIS screw driver (not Phillips), and you won't have to worry about stripping screws.
yyonline
Return to How To
