[How to] Solid fill your engine mounts
Re: [How to] Solid fill your engine mounts
Postby maxaud » Wed Mar 10, 2010 5:59 pm
klue wrote:..either way you need to check up on the mounts after a while...
Now would be a good time since this thread is two years old (2.5 from OP).
-Dustin
maxaud
Postby klue » Wed Mar 10, 2010 7:16 pm
agreed!
Postby Dups90gt » Sat Mar 13, 2010 12:02 am
so whats *** ? I wanna solid fill my mounts
Dups90gt
Postby klue » Sat Mar 13, 2010 5:57 am
dups, you can get the stuff at rona.
its called polyurethane adhesive, its in a yellow tube.
I could tell you the exact one but id have to see it to identify,
Postby Dups90gt » Sat Mar 13, 2010 12:44 pm
I'm there, thanks Luke!
Dups90gt
Postby tw2 » Sun Mar 14, 2010 2:29 am
Next time I am under the car I will have a look at how they are staying together. I didn't realize I had done this so long ago.
Thomas, JDM 90 185, 06 350z
tw2
Postby Hotrodhendrix » Tue Aug 30, 2011 7:08 pm
Just an update. I did mine back in 07 and they still look just as they did then.
Postby Killtodie » Sun Dec 30, 2012 2:30 pm
I did something similar, but used 80A Urethane Casting Compound. 1lb was only enough for 3 mounts, but I left the fourth in the car anyway.
Dries in about 5 hours, technically takes 7 days to fully cure, but should be usable within 48 hours. I have not driven the car on them yet.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby ZeroDrift » Sun Dec 30, 2012 3:12 pm
I did this a while back for a few mounts and used the shore 60A kind. They didn't hold up very well as they had a few mm of sag when I removed my engine. The main issue is the mixing process of the urethane adds a large amount of air into the mixture and the vast majority of the air remains trapped in the mount. After talking to some more experienced folks about this it was highly recommended to put the mixed urethane in a vacuum chamber for a few minutes to remove excess air. I plan to remake my mounts with this method in the near future.
Postby Killtodie » Wed Jan 16, 2013 11:17 pm
I noticed cracking and saggin as well, disappointing.
should the poly be out in a vacuum before or after pouring?
Killtodie
Postby ZeroDrift » Wed Jan 16, 2013 11:46 pm
I would imaging the bare minimum would be just after the mixing process and being careful to avoid a "sloppy" pour that would introduce fresh air into the mix.
Best bet is to purge air after both steps.
Postby tw2 » Thu Jan 17, 2013 4:49 am
I never had any problems with mine and you can see from my old pics they looked a complete mess. It must depend very much on the type of product used. I also didn't have any issues with air getting into the mixture.
tw2
Return to How To
