[How to] Remove the ABS from a ST185
Re: [How to] Remove the ABS from a ST185
Postby alexinvancouver » Tue Jan 29, 2013 5:23 pm
celigts wrote:Flare tool you mean? How long did it take you guys to do? And how much did you remove to get to the firewall stuff while the motor was installed.
flare tool, that's it =o)))
i actually did on my 00 Subaru Impreza 2.5RS without removing the engine and it took about a day
i haven't started working on Celica yet, just removed ABS computer for now.
i don't drive it. it's a project car and hopefully i'll start working on it full scale this summer
1990 Celica Alltrac
2001 Impreza RS Stage Rally car
2006 Honda Ridgeline
2014 Subaru Impreza
alexinvancouver
Postby celigts » Wed Jan 30, 2013 4:23 am
I'm SO tempted to do this next week... But scared I'm gonna f*** something up.
3SGTE project motor very slow
celigts
Postby toayoztan » Wed Jan 30, 2013 11:42 pm
I'll be doing this, since I removed my ABS.
I'll try a mini write up, although it will be based on having the motor out.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby celigts » Thu Jan 31, 2013 3:00 am
toayoztan wrote:I'll be doing this, since I removed my ABS.
Bryan
I'm sure you can still mention the difficulties of certain areas but otherwise I'm MOSTLY worried of re installing the lines after removing them from the box and also with using the p pipe? From the abs box.
celigts
Postby toayoztan » Thu Jan 31, 2013 3:45 am
Bryan
Using the ABS P-valve should be ok if your ABS was originally working. If the ABS wasn't working, then I would definitely get the valve checked out.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby celigts » Thu Jan 31, 2013 3:55 am
Nope the abs works. Just disagree with it working better then manually using the brakes. It's just come in the way stopping on ice and anything but highway lol.
celigts
Postby toayoztan » Thu Jan 31, 2013 4:02 am
celigts wrote:Nope the abs works. Just disagree with it working better then manually using the brakes. It's just come in the way stopping on ice and anything but highway lol.
Yeah our ABS is archaic and I just don't like the way it operates or feels when I drive the alltrac. That's why I ripped it out and will be using the ABS p-valve to replace the one on the firewall.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby celigts » Thu Jan 31, 2013 4:21 am
PLEASE! Take pics of the valve on the brick and how it's assembled to the lines in the end.
Is the p-valve on the brick replacing the stock p-valve or what's the point in replacing? Sorry .. I'm a little slow at most DIY stuff haha
celigts
Postby darthripley » Thu Jan 31, 2013 4:42 am
Honestly, I rarely say what I'm about to say, but your statements & questions tell me you haven't thoroughly read what I have written.
Please read through the first post on this thread - there is a ton of info already there.
You need a different p-valve as the ABS brick will be removed from the equation, therefore completely changing the whole set up. There's a reason Non-ABS setups had a different p-valve.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby celigts » Thu Jan 31, 2013 5:09 am
darthripley wrote:Honestly, I rarely say what I'm about to say, but your statements & questions tell me you haven't thoroughly read what I have written.
Yea I don't understand the write ups all the time :/ just seem to blur everything when I read. Not a reader so that's my downfall about doing stuff I can't have someone help me with.
I understood that you can use the use p-valve from the abs brick in place of the stock one...
celigts
Postby sMARTINside » Thu Jan 31, 2013 12:30 pm
Don't forget that you can also replace the valve by an adjustable aftermarket one that is brand new for under 100$. I did this using this valve. It made the brakes very adjustable and FUN to drive. I never had a vehicle that brakes that good. I was so pleased with the results that I did the same thing on my racing Tercel, last year.
Wilwood #260-11179
http://www.wilwood.com/MasterCylinders/MasterCylinderProd.aspx?itemno=260-11179
sMARTINside
Postby celigts » Thu Jan 31, 2013 2:57 pm
Your link is broken.. Gay!
celigts
Postby toayoztan » Fri Feb 01, 2013 2:17 am
sMARTINside wrote:Don't forget that you can also replace the valve by an adjustable aftermarket one that is brand new for under 100$. I did this using this valve. It made the brakes very adjustable and FUN to drive. I never had a vehicle that brakes that good. I was so pleased with the results that I did the same thing on my racing Tercel, last year.
Wilwood #260-11179
How much did you adjust to the rear and front, with what brake set up in the rear and front?
I plan to run all stock for now, but eventually BBK up front with stock rear.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby sMARTINside » Fri Feb 01, 2013 9:22 am
This valve can adjust from 0% to 57% to the rear wheels. I can't tell you how it's adjusted right now on my Celica. It's a matter of feeling, trying to find the sweet spot, but I like more in the rear than the stock valve does. I am running stock brake size all around. I my Tercel, I installed it inboard so I can play with the proportion while I am racing (saves pit stops! :D ).
sMARTINside
Postby darthripley » Fri Feb 01, 2013 7:30 pm
celigts wrote:Yea I don't understand the write ups all the time :/ just seem to blur everything when I read. Not a reader so that's my downfall about doing stuff I can't have someone help me with.
Sorry didn't mean to come down on you. I read a lot & that's how I understand things best, but not everyone learns the same way.
When we did the removal, the write-up that was exisiting had no pics & we were completely on our own as far as how to do it, what parts were needed etc. so even if it doesn't make total sense to you right now it's a whole lot better than what was here to begin with.
Bryan will add more to the how-to with more pics & also with the wiring removal from the loom as well.
Female Moderator
darthripley
All Trac Goddess
Return to How To
