[How to] remove fuel pump without dropping the tank
Postby celigts » Mon Nov 05, 2012 6:51 pm
Is it possible? I've been told both it is and it isn't. I know there is that black cap in the hatch of my 185 that has wires going to it. Will this be an access point to the pump?
Really need to figure this out cuz I need to deal with my personal fuel/lean at running issue and really don't want drop the tank. It's my DD so it can't be down for more then a weekend.
Please post any info you have on the subject.
Thanks guys
3SGTE project motor very slow
celigts
Re: [How to] remove fuel pump without dropping the tank
Postby Spectra1 » Mon Nov 05, 2012 7:52 pm
I remember someone mentioning it can be done but from my experience I cant see how it is even remotely possible. The little access in the hatch area gives you access to the sender for the fuel level gauge, the pump is then further towards the front of the car. I ended up cutting a square access hole in the hatch floor and I am planing on covering it with an aluminum plate. Now I can always access the fuel pump quickly without the hassle of dropping the tank.
93 St185 DD
90 ST185 - Project
Spectra1
Postby quieter » Mon Nov 05, 2012 8:41 pm
you will need to drop the tank,
1990 toyota ST185 with st205 goodies (scrapped)
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby 4rsnduction » Mon Nov 05, 2012 9:47 pm
Hope this helps
You do not have the required permissions to view the files attached to this post.
4rsnduction
Return to How To
