ST205 swap questions
• Page 2 of 2 • 1, 2
Re: ST205 swap questions
Nope the cables can't be swapped they have different end types at the shifter.underscore wrote:maybe a dumb question, but is there any chance you have the cables swapped at one end or the other (or both?)
Someone help me verify at the transmission. One moves the plunger and one moves the lever back and forth. I have the cable on the side of the shifter going to the plunger. The cable that goes to the bottom of the shifter rod goes to the lever.
simple - Club Member
- Images: 1
Looking at Project Binky quickly the cable coming through on the left (facing the firewall from the front of the car) goes to the side-side arm on the trans (actually into gears) and the one that comes through on the right goes to the front-rear arm on the trans.
Great info but need to know where it connects to shifter not left/right in firewall.
- Images: 1
Just swapped left/right and it definitely didn't feel right.
- Images: 1
Well I finally got another set of shift stock St165 cables to utilize! Grabbed some new bushings from prime/racerX.
Expensive solution but hey it's gonna be nice to get past this issue
- Images: 1
