ST205 Carina ED: manufactured from May 1994 until April 1998
There was also the earlier ST16x & St18x version. Basically a 4 door Celica platform.
1994 model
http://www.cars-directory.net/specs/toy ... 94_5/1933/
1996 model
http://www.cars-directory.net/specs/toy ... ed/1996_6/
GT-4WD exciting version equipped car
Engine 3SGE
Body type Hardtop
Drive FULL 4WD
Transmission 5 speed manual
Displacement, cc 1998
Frame E-ST205-CTMVF(E)
ENGINE
Engine model 3S-GE
Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.5 kg*m (191.23 N*m) / 4800 rpm
Power density 7.77
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information Horizontal ranging
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10.3
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.2
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 205/55r15 87v
Tires size rear 205/55r15 87v
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring (stabilizer attaching) super strut suspension
Suspension system, rear Strut type coil spring (stabilizer attaching)
cool, the car is listed on my EPC (electronic parts catalogue) 8)
its a 4wd Carina with superstrut suspension, crappy brakes.
Some appear to be 4ws. (4 wheel steer)
Fom what i can make out....The rear diff is an open differential, ie different to the TorSen rear differential in the ST205 Celica GT-Four :shrug:.
