Exactly what the title says, the car seems soo slow, when i put it down in a higher gear and low rpm, it hits full boost at ~12-13 and it shutters, the whole car just shakes, then when it finally catches on and stops shaking it goes but not fast at all it sometimes jumps and goes normal for honestly 3 seconds then goes back to going slow, seems like i have a vacuum line leaking or something?
I'm getting a cel, 31 and 24 and the regular 54 which i've had for ever.
I got out of my car and checked under the hood yesterday and the exhaust side of my turbo was bright yellow, a tad hot.
and i could hear mass bubbling in the rad ( I let the air out of that so thats fine now).
Would the turbo heat up cuz its running lean? And possibly having an open vacuum line would cause it to be sucking air in which would make it run lean? I'm just throwing those out there, possible suggestions. THe car runs ok after a little while of driving, SOMETIMES.
